Oil Cooler Adapter Not Working?
I recently installed an oil cooler adapter from Improved Racing (LS low profile), got the oil up to temp and the actual cooler is still...cold. Temp sensor is showing 240 degrees and I still have good oil pressure, so I'm guessing the thermostat in the adapter is bad? I just can't believe I'd have bad enough luck to get a new part with a failed thermostat. I REALLY don't want to take that all apart again, very tight in there.
Anything I could be missing?
jpkinerk- Posts : 174
Re: Oil Cooler Adapter Not Working?
might be helpful to share more about your setup. what oil pan do you have? are you running a remote oil filter?
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
