» Tpc LS adapter plate
» Headers, headers, HEADERS!
Oil and steering cooler options
Post  rooster on Fri May 11, 2012 1:33 pm
I'm trying to sort out how to best set up an oil cooler and power steering cooler and need some input before I order parts.
For those who have an oil cooler; how large a cooler do you have? Care to share a part number? Also are the tube/fin types sufficent or do I need to pony up for the sandwich plate type? There are tons of coolers on Summit and a bunch of trans cooler options too. Is there any reason why a trans cooler would not work as an oil cooler? oil is oil no? Finally, I see a few guys have run an oil thermostat, is this essential or only for colder climates where the oil might not get up to temp. I live in the midwest and plan to use the car in the spring and summer only, 85% lapping days and 15% street.
On to P/S - Since I plan to track the car and run Hydroboost I picked up a Turn1 pump and have been told to add a cooler for the P/S fluid or it will boil. Has anyone used the stock 951 oil cooler as a P/S cooler? I have a local source for custom lines so I should be able to get it plumbed up. Does anyone see a problem with this idea? It's just sitting there and I'd prefer to recycle instead of buying more parts....... damn this project is snowballing. Shocked
Thanks for the help.
-Andrew
rooster
Re: Oil and steering cooler options
Post  zeusrotty on Fri May 11, 2012 2:18 pm
I can tell you that I bought a trans cooler from Flexalite and use it as a power steering cooler. It was only 35.00 and easy to plumb and install.
zeusrotty
Post  Lemming on Fri May 11, 2012 4:53 pm
Search "cxracing oil cooler" on ebay. Inexpensive, yet pretty good quality. I believe I have the 25 row on my track car and it works well. In the past I bought a few intercoolers from them and the quality is surprising for the price. No issues to date.
Cooler
Post  fliermike45 on Fri May 11, 2012 10:00 pm
I have a turn one pump also, I transfered the stock oil cooler from pax to driver side and plumbed it into the PS return line. I'm in the process of adding Hydroboost and hope this cooler setup will be sufficient for both syatems.
Post  rooster on Sat May 12, 2012 1:56 pm
Thanks for the help folks. I've got an oil cooler on order and I'll try and plumb up the stock 951 oil cooler to the P/S lines.
One of these days I'll start my own build tread, I'm at the point where the real work begins - finally!
rooster
Post  docwyte on Sat May 12, 2012 11:09 pm
I have a mocal 11*7*4 cooler, it was the largest I could go with without front mounting it. I just went with a cheapie ps cooler from summit racing, world great.
Post  marc a on Mon May 14, 2012 9:49 pm
Here's mine:
The thermostat is to make sure that the cooler is not subjected to the initial pressure surge when the oil is cold, and thereafter to gradually introduce hot oil into the cooler and control the temp. Make sure the pressure rating for the cooler is up to the task. Not sure if the pressure rating for a tranny cooler is high enough for an oil system.
marc a
Post  zeusrotty on Tue May 15, 2012 6:00 pm
Do you need an oil cooler on an LS2 for the track?
zeusrotty
Post  docwyte on Tue May 15, 2012 6:11 pm
It'd be a very good idea.
