WTB: early N/A 5th gear
Looking for early N/A 5th to swap into my turbo trans.
948inVA- Posts : 224
Re: WTB: early N/A 5th gear
I've got one that I can swap for your turbo 5th.
johntorg- Posts : 69
Thanks for the offer, but I already found someone local to swap with.
Is it a hard swap? I have a NA trans that I am using as a donor for my AOR LSD unit.
piperporsche180944- Posts : 6
It is pretty straight forward. You will need to find a thin jaw gear puller or just file out a standard 3-jaw one in order to fit it in the gear lip to pull out the 5th gear stack out.
Agreed, some of the write-ups on it are a little confusing but Dimi brought over his gear puller and we had it out in no time. The heat gun really helped when putting everything back together.
» Any interest in a long 5th gear set from an early NA?
» Front and rear Euro Bumpers
» Early SBC - SpacerPlate FS
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
