A/C high pressure switch
Time to get my ac going again. Last summer it worked ok,but I noticed on drive longer than. 45 min it seemed not.to be cooling that well. When my car first hit the road all I used on the ac system was the low pressure switch. I think the camaro ac system uses high and low switches. I need guru help! Should I install a high pressure switch and wire it to what the ac relay. I am using the porsche set up with the ls1 ac compressor.
ROGUE S2- Posts : 35
AC QUESTION
First a question, are you controlling the compressor clutch with the PCM?
If so I believe you need high and low pressure switches connected to the PCM.
Please ask another GURU about this.
If you are controlling the compressor clutch with the Porsche AC dash switch then the Porsche high and low pressure switches on the receiver/drier will take care of the pressures.
BUT if this is the case you must modify the internal valve inside the F body compressor to convert it from a variable pressure compressor to a fixed pressure compressor to be compatible with the Porsche system. I believe the compressor shuts down if you don't do this. You also need relay(s) to control the cooling fans when the clutch engages.
If you email me at flier1998@yahoo.com I will send you the details on how to do this modification.
» Help with pressure plate (SPEC pressure plate doesnt fit!!)
Yesterday at 3:06 pm by Rob44
