Race built LT1
Race built LT1
I'll make a heck of a deal on this race built motor, estimate 350-400 HP
edlebrock lt4 intake
30lb bosch injectors
Comp EFI cam
Comp Cam steel roller rocker
Comp Cam beehive valve springs
Aluminum heads - GM
Meizer electric water pump
58 mm Throttle body
New optispark
ARP studs and hardware
Chrome valve covers
MSD ignition wires
MSD coil
Clevitt nascar bearings
Balanced and polished GM crank
Available with and with out the headers.
Also have SPEC 12lb flywheel with street or stage 3 clutch and PP
PM or email for the deal!
Comp EFI cam
Aluminum heads - GM
58 mm Throttle body
New optispark
Chrome valve covers
MSD ignition wires
MSD coil
» 944 V8 representing at open road race in 2012
» Hanging it out over Madness/ the debut of the Franken44
» Porsche Palace
» Porsche Palace
Yesterday at 8:32 am by Rob44
Yesterday at 8:28 am by Rob44
