LS1 Intake EGR Delete Plug behind Throttle Body
Here is a nice piece to use to plug the EGR hole behind the TB on LS1 intakes. I have seen the freeze plugs & expanding rubber, effective but not very pretty. Found on EBAY. Billet aluminum with machined O-ring to plug hole. I will try to post a pic or here is a link.
yeehaa- Posts : 1
Re: LS1 Intake EGR Delete Plug behind Throttle Body
Looks good, also looks like a lot of work to create a Federal offense...
Admin wrote:Looks good, also looks like a lot of work to create a Federal offense...
You forgot to mention that it creates zero gain in HP. (since EGR is not used a WOT) It's awesome how much work some of us make over nothing, except for the fact that it's an emissions item.
Dawgz83948- Posts : 603
It's a federal offense to remove a plug that removes a few PPM of particulate, but O.K. to let a B.O.P. go out of spec and dump millions of gallons of crude.....
xschop wrote:It's a federal offense to remove a plug that removes a few PPM of particulate, but O.K. to let a B.O.P. go out of spec and dump millions of gallons of crude.....
It's a federal offense to make a plug that increases NOX emissions.
Don King said it so eloquently......."Only in America"
Dumb question
My 2001 C5 Vette intake manifold is not capable of taking this plug, is there a difference?
The 2001 corvette does not have the egr system from the factory. they changed the cam enough to get rid of the egr.
Yesterday at 3:06 pm by Rob44
