» Tpc LS adapter plate
» Headers, headers, HEADERS!
LS1 Intake EGR Delete Plug behind Throttle Body
Post  yeehaa on Sun Apr 03, 2011 10:58 pm
Here is a nice piece to use to plug the EGR hole behind the TB on LS1 intakes. I have seen the freeze plugs & expanding rubber, effective but not very pretty. Found on EBAY. Billet aluminum with machined O-ring to plug hole. I will try to post a pic or here is a link.
yeehaa
Re: LS1 Intake EGR Delete Plug behind Throttle Body
Post  Admin on Mon Apr 04, 2011 7:37 am
Looks good, also looks like a lot of work to create a Federal offense... Shocked
Post  Dawgz83948 on Mon Apr 04, 2011 9:33 am
Admin wrote:Looks good, also looks like a lot of work to create a Federal offense... Shocked
You forgot to mention that it creates zero gain in HP. (since EGR is not used a WOT) It's awesome how much work some of us make over nothing, except for the fact that it's an emissions item.
Post  xschop on Mon Apr 04, 2011 12:06 pm
It's a federal offense to remove a plug that removes a few PPM of particulate, but O.K. to let a B.O.P. go out of spec and dump millions of gallons of crude..... Razz
Post  Dawgz83948 on Mon Apr 04, 2011 12:13 pm
xschop wrote:It's a federal offense to remove a plug that removes a few PPM of particulate, but O.K. to let a B.O.P. go out of spec and dump millions of gallons of crude..... Razz
It's a federal offense to make a plug that increases NOX emissions.
Post  xschop on Mon Apr 04, 2011 12:17 pm
Don King said it so eloquently......."Only in America"
Dumb question
Post  fliermike45 on Mon Apr 04, 2011 8:43 pm
My 2001 C5 Vette intake manifold is not capable of taking this plug, is there a difference?
Post  Admin on Tue Apr 05, 2011 7:27 am
The 2001 corvette does not have the egr system from the factory. they changed the cam enough to get rid of the egr.
Thank you
Post  fliermike45 on Tue Apr 05, 2011 7:30 am
Many thanks.
