5th gen Camaro accesories
Has anyone used 5th gen Camaro ls3 accesories on a 944 ls swap? The AC and alt are low mount like the ls1 f body but I believe they are spaced further away from the block.
RossPerformance- Posts : 2
Re: 5th gen Camaro accesories
It depends on the Camaro engine/transmission option - Manual: LS3; or AT: L99.
Whenever I have absolutely nothing more important to do...I work on my project (and at a glacial speed, mind you) where I’m using a low mileage 6.2L from an Escalade with the L92 engine option…as in a variable valve timing (VVT) cam but without any of the Active Fuel Management (8 to 4 cylinder) solenoid activated hydraulic valve lifters hardware.
I topped it off with a LS3 intake and a FEAD swapped from a Camaro L99 engine (w/auto trans option, that is a 6.2L with both the VVT & AFM option), requiring GM engineering adding up front spacing for AT equipped Camaros to the basic LS3. My swapped L99 FEAD stuff, e.g. WP, PS pump, automatic belt tensioner, alternator etc, and also the lowered L99 throttle body, all appear to neatly clear the hood on my project. But truthfully I haven’t put the hood back on yet. (btw, most folks recommend a manual belt tensioner, and another btw, I'm using Smith Brother 'Oil Restrictor' push rods as these engines seem to send too much oil to the top end sometimes starving the bottom end.)
The L92 and/or Camaro L99 VVT/AFM solenoid is located behind the front cam cover adding ¾” to the length of an LS3 engine. As my original Escalade L92 engine came with the usual GM ‘truck’ Front Engine Accessory Drive (FEAD) including an extended crankshaft pulley/harmonic balancer, I’m assuming the L99 Camaro uses either the same or a very similar crank pulley as now all my accessory pulleys line up perfectly with the serpentine belt. And btw…I’m using the original ‘truck’ a/c compressor mount.
I’ve had the engine in & out several times and the next time I put it in with (headers & a mini starter) I’ll take pictures. Welcome & hope this helps.
944convert- Posts : 253
Thank you for the response! I’m happy to hear someone has tried them and they seem to fit.
» '98 CORVETTE MOTOR F BODY ACCESORIES
» LS3 OE Camaro / Vette Exhaust Manifolds
» WTB LT1 Camaro accesory bracket
Yesterday at 9:41 pm by MotoRider42HC
» 944 LM4 5.3 swap for sale
Yesterday at 2:35 pm by secheltguy
» Adapt VSS to early car mechanical speedometer?
Yesterday at 1:59 pm by Hey_Allen
» 88 951 LS1 TRACK CAR FOR SALE
Yesterday at 9:45 am by Dawgz83948
» Turbo Transaxle NA swap (Non-lsd to LSD)
Wed Nov 06, 2024 2:01 pm by Krowdy
» Any Custom Exhaust Installers Tri-State Area?
Sat Nov 02, 2024 10:13 am by 87roadracer
Sat Nov 02, 2024 9:24 am by haroldk
» 951 Transaxles For Sale
Tue Oct 08, 2024 11:04 pm by Andy87944NA
» Modified 944 Front Suspension - Complete
Mon Oct 07, 2024 9:51 am by 944_GASM
» Monster wide body LT-1 for sale
Sun Sep 29, 2024 7:23 am by 944-LT1
