» Blowing A Racing Engine (Dropped A Valve)
Accessory Power and Fuel Pump, Where? EmptyYesterday at 9:41 pm by MotoRider42HC
» 944 LM4 5.3 swap for sale
Accessory Power and Fuel Pump, Where? EmptyYesterday at 2:35 pm by secheltguy
» Adapt VSS to early car mechanical speedometer?
Accessory Power and Fuel Pump, Where? EmptyYesterday at 1:59 pm by Hey_Allen
» 88 951 LS1 TRACK CAR FOR SALE
Accessory Power and Fuel Pump, Where? EmptyYesterday at 9:45 am by Dawgz83948
» Turbo Transaxle NA swap (Non-lsd to LSD)
Accessory Power and Fuel Pump, Where? EmptyWed Nov 06, 2024 2:01 pm by Krowdy
» Any Custom Exhaust Installers Tri-State Area?
Accessory Power and Fuel Pump, Where? EmptySat Nov 02, 2024 10:13 am by 87roadracer
» What coilover spring rates are you running with torsion bar removed?
Accessory Power and Fuel Pump, Where? EmptySat Nov 02, 2024 9:24 am by haroldk
» 951 Transaxles For Sale
Accessory Power and Fuel Pump, Where? EmptyTue Oct 08, 2024 11:04 pm by Andy87944NA
» Modified 944 Front Suspension - Complete
Accessory Power and Fuel Pump, Where? EmptyMon Oct 07, 2024 9:51 am by 944_GASM
» Monster wide body LT-1 for sale
Accessory Power and Fuel Pump, Where? EmptySun Sep 29, 2024 7:23 am by 944-LT1
November 2024
Accessory Power and Fuel Pump, Where? Empty Accessory Power and Fuel Pump, Where?
Post  robstah Sun May 01, 2011 4:06 am
So, where is everyone grabbing the accessory (key on) power and fuel pump feed? I plan on deleting the stock DME and fuel pump relays and running a standalone harness like what lt1swap.com mentions ( http://www.lt1swap.com/fuseblock_obd2port.html ).
Accessory Power and Fuel Pump, Where? Empty Re: Accessory Power and Fuel Pump, Where?
Post  spence Sun May 01, 2011 5:42 am
Tie into a 12v switched source from the drivers side of the radio fuse. The green/Blk wire at the 14-pin connection in the engine bay goes to the fuel pump IIRC.
Post  robstah Sun May 01, 2011 7:17 am
And here I thought that only the 3 sensor wires were worth it on the 14 pin... Suspect
So the green/black just goes straight to the pump? So there is no fuel pump relay? Also, is there an accessory that could be pulled from the 14 pin as well?
(right click and view image to see the whole thing)
Accessory Power and Fuel Pump, Where? 8fuMh
Post  spence Sun May 01, 2011 9:35 am
You'll need a new relay for the fuel pump & a new relay for 12v switched power.
Once you pull the DME relay I think it kills the power to the 12v accessory you are talking about. Just tap into the radio fuse for the 12v switched relay signal.
Post  spence Sun May 01, 2011 9:43 am
This might help you. Follow XSCHOP's diagram.
Accessory Power and Fuel Pump, Where? 948fus11
Post  Arthropraxis Sun May 01, 2011 12:20 pm
Are the pink 3's in line fuses to the main switched relay and the pcm fuel pump? If so what size fuse should be used?
Post  spence Sun May 01, 2011 1:21 pm
Ya, it looks like there inline fuses. I did mine a little different and ran everything to one fuse box. The 3's mean a 3amp fuse is used.
