1998 LS1 (GM) Part Numbers
LS1 Parts List
Engine:
12160244 IAT Sensor
24504388 IAT Sensor Grommet
10238852 LS1 Pushrod
12552954 LS1 Timing Chain
12559271 Water Pump Gasket (need 2)
12561244 Front Crank Seal
12557840 Crank Pulley Bolt
12558013 Timing Cover Gasket
12558573 Exhaust Manifold Gasket
12559188 98-99 AIR Tube (one side)
12559189 98-99 AIR Tube (other side)
12556643 98-99 EGR Tube
12553047 EGR Gasket
12553617 AIR Tube Gasket
12557932 EGR O-ring Seal
12560696 Valve Cover Gasket
12565117 LS6 Valve Springs
12560950 LS6 Camshaft
12568002 LS6 Valley Cover
12658010 LS6 PCV Kit
88890523 LS6 Intake
12568478 2001 Coolant Pipe
12562788 2001 Coolant Plug
10096163 Coolant Level Sensor
12560744 "M-11" Head Bolts (need 8/side)
12560745 "M-11" Short Head Bolt (need 2/side)
12558840 OR 12558845 "M-8" Head bolts (need 5/side)
12558809 Head Gasket (drivers side)
12558810 Head Gasket (pass side)
12556643 98-99 EGR Tube Assembly
12556436 2001 Oil Pump
16238212 Computer (PCM) 1998
12177561 Engine Harness 1998 (manual)
25312196 RH O2 sensor
25312197 LH O2 Sensor
12558948 Coil
12560228 Crank Sensor
12560229 Cam Sensor
12555424 Belt Tensioner
10456603 Knock Sensor
9353691 Body Control Mod. (BCM)
15301401 Coil Harness
25179711 LS1 MAF
12160244 IAT Sensor
12552059 Water Pump Pulley
25179711 00' Mass Air Sensor (whole assembly)
12561269 Intake Manifold for 98-00 F-body
88890523 Intake Manifold for 01 F-body
12557846 Intake Manifold for 98-00 Y-body
88890524 Intake Manifold for 01 Y-body(LS1 & LS6)
12560965 Camshaft for 98-00 F-body
12560964 Camshaft for 98-99 Y-body
12560968 Camshaft for 00 Y-body
12561721 Camshaft for 01 F-body & LS1 Y-body
12560950 Camshaft for 01 Y-body LS6
12560194 Left Exhaust Manifold for 98-99 F-body
12561308 Left Exhaust Manifold for 98-99 Y-body
12559507 Left Exhaust Manifold for 00-01 F-body
12562638 Left Exhaust Manifold for 00 Y-body
12561255 Left Exhaust Manifold for 01 Y-body LS1
12561256 Left Exhaust Manifold for 01 Y-body LS6
12560193 Right Exhaust Manifold for 98-99 F-body
12561309 Right Exhaust Manifold for 98-99 Y-body
12559506 Right Exhaust Manifold for 00 F-body
12562639 Right Exhaust Manifold for 00 Y-body
12567706 Right Exhaust Manifold for 01 F-body
12561256 Right Exhaust Manifold for 01 Y-body (LS1 & LS6)
17113390 Throttle Body for 98-99 F-body
17113564 Throttle Body for 98-99 Y-body
17113647 Throttle Body for 00-01 F-body
17113669 Throttle Body for 00-01 Y-body (LS1 & LS6)
12533952 Injector for 98 F-body & Y-body
12456154 Injector for 99-00 F-body & Y-body
12482704 Injector for 01 F-body & Y-body (LS1 & LS6)
12558807 Heads for 98 F-body & Y-body
12559855 Heads for 99-01 F-body & Y-body (LS1)
12560801 Heads for 01 Y-body (LS6)
12480033 Hot cam for LS1
12555685 Mobil 1 Oil Cap
10236268 Mobil 1 Sticker
12556455 + 12559261 Fuel Rail Covers
12564257 + 12564258 Z06 Fuel Rail Covers
Clutch/Transmission/Driveline
12562765 LS1 Flywheel
12570277 Clutch Master Cyl.
12570281 Z06 Clutch, P. Plate, Flywheel
12562765 2001 F-body Clutch, P. Plate, Flywheel
12565145 2001 Slave Cyl.
15046288 2000 Slave Cyl .
12570281 Z06 Clutch
Engine:
12160244 IAT Sensor
12553047 EGR Gasket
88890523 LS6 Intake
12558948 Coil
12560229 Cam Sensor
25179711 LS1 MAF
12160244 IAT Sensor
12570281 Z06 Clutch
gt1scca- Posts : 795
Punisher948 likes this post
Today at 3:06 pm by Rob44
