new buyer, looking for info
+2
gamman
6 posters
Does the manual show a converted car's weight? I am looking at a 88 944s LT1 RH home conversion, and the owner is stating that the car is around 2700lbs with a so so diet.
Things like water resevoir for windshield is gone, as are back seats and rear wiper. Most else is there, apart from headlight motor and headlight transmission, he has a fancy magnet and "cam lock" slider holder you need to slide with your fingers to make the HL stay up. Pretty neat actually.
Weight seems a little on the optomistic side, as some places put the stock 944S around 3,000lbs (trackepedia). Pelican has 944s at 2637, heck, even uh, a manufacturer says 1280kgx2.2=2850 with a 4cyl stock. Anyone weighed theirs? Its too snowy here to drive to a truck stop. I will be corner weighing, once I buy it and get an adjustable set of suspension stuff.
Love the site, I will be having an inspection today and hopefully a new owner by Friday.
Where do I find or figure out what are the weak points of the RH conversion? I know there are things you guys don't like, i just haven't read between the lines enough (and they have been removed elsewhere) with the RH kit.
gamman- Posts : 112
Re: new buyer, looking for info
COST AND CUSTOMER SERVICE, THAT IS WHAT STARTED THIS SITE AND EVERYONE'S DRIVE TO DO IT OURSELVES.
2700 is not out of the question even for a iron block car. Getting in that range is reachable without AC and supporting Porsche hardware, no cat, no factory sound deading, getting rid of the factory carpeting and so on.
944v8inDFW- Posts : 147
OH and RH has taken over kingofchode.com as well. Crappy deal but you got to keep a finger on the competition!
944v8inDFW wrote:OH and RH has taken over kingofchode.com as well. Crappy deal but you got to keep a finger on the competition!
What is kingofchode.com?
As I understand it the chode was discovered and named by Da Vinci, during his anatomization (dissections) first thought to be a vey important part to maintain balance. Then later discovered to be just a worthless waste of skin.
So somewhere in the last 100 years or so it has became a slang / dirogitory term for a fu**up or being worthless. We commonly call the chode of Da Vinci discovery the “taint"
So we can extrapolate a chode is half a**hole half ballsack.
...And I was one of the "Choden (or "Tainted") Ones" in June.
Rage Against The Machine has something for that...
(I am not a DJ, but I do enjoy dat funkee muzak ocassionally, Wyte Boyeee)
"...While on the corner
The jury's sleepless
We found your weakness
And it's right outside your door
...Now testify
It's right outside your door...
Who controls the past now controls the future
Who controls the present now controls the past
Who controls the present now?
...Now testify."
Uhhhh...
Spin it one time DJ Mann.
...Now testify
...Now testify."
Uhhhh...
gt1scca- Posts : 795
That's my kinda Flava....
Yeaaaaah Boiiiiiiiiiiii
» Rear wheel question.
» Pair of XSCHOP's willwood big brake brackets with centering rings brand new!
» What is the best color for a 944?
Today at 3:06 pm by Rob44
