Today at 6:52 pm by chrenan
Today at 5:45 pm by AMFCSL
» Tpc LS adapter plate
Today at 5:41 pm by jimbag
» Headers, headers, HEADERS!
» Electric brakes
Leaking Slave Cylinder (clutch)
Post  968gene on Sun Nov 28, 2010 8:15 pm
has anyone had this issue?
968gene
Re: Leaking Slave Cylinder (clutch)
Post  944-LT1 on Sun Nov 28, 2010 11:23 pm
Were assuming a C5 internal style slave cylinder here?
Post  xschop on Mon Nov 29, 2010 5:30 am
Aftermarket line kit? The O-ring insert on the feed line could be crimped.
C5
Post  968gene on Mon Nov 29, 2010 7:21 am
Its either a C5 or an S10.
I'm using an aftermarket line to the MC. It appears to be leaking from the line end, but the Quicktime bellhousing will need to come off first (engine removal etc.) I am also reading on another forum that the Spec clutch might need measuring and shimming to avoid over running the slave and popping the seal. No good news.
968gene
Post  Admin on Mon Nov 29, 2010 7:26 am
If you are using the spec clutch you have to use the shim that comes with it for the C5/S10 slave cylinder. If you get it apart and do not have one in there give me a shout. I have a few and can get more.
Post  968gene on Mon Nov 29, 2010 7:28 am
Its been many months since I did the install. Do you have a picture of a shim? That might jog my memory. Gene
968gene
Post  xschop on Mon Nov 29, 2010 9:32 am
Hey Gene, thought you were running the C5 2 piece BH with my adapter plate. So you'll have to remove the engine? That sucks. It is a crap shoot with the Spec clutch and the shimming being correct if you cannot visually measure the PP spline engagement with the TO bearing. Sad but true.
Post  Porch on Mon Nov 29, 2010 9:37 am
I'm curious what they look like too, and i think i'm going to need one!
Post  Dan J on Wed Dec 01, 2010 8:08 am
Here's a photo of the shim.
My setup is the same as yours, Spec clutch + S10 cylinder with the Wilwood MC. My car isn't on the road yet, but will report back if the slave leaks. As of now it's bled and the clutch action seems fine. I checked slave install instructions and don't see the total travel listed. So, not sure just how far it goes before over-travel.
BTW, one idea to consider. Instead of removing the motor you might cut the shim down the middle. If you release the pressure on the slave you could likely slip each half of the shim under w/o pulling the motor.
Hope this helps.
Dan
Dan J
Leaking Slave
Post  968gene on Wed Dec 01, 2010 8:32 am
Thanks Dan. Your suggestion is welcomed, but I have a Quicktime BH installed. Since it is one piece, the engine must come out. affraid
968gene
Post  xschop on Wed Dec 01, 2010 9:05 am
Hey Guys. I've always wondered about the S10 TO bearing. The C5 TO bearing has an internal catch that doesn't let it over extend. So are you guys saying the S10 TO bearing can go past it normal resting point when fully extended?
BTW Dan, that is a good idea with slotting the spacer plate.
Post  Dan J on Wed Dec 01, 2010 9:39 am
I don't know if it's over-extending or not. I'm using the 2-piece bellhousing and can check to see if it leaks when the pedal is depressed all the way. If it is a problem another option may be adjustment of the pushrod and pedal.
Sorry about the 1 - piece bellhousing thing, are you sure there's not enough adjustment available in the pedal and pushrod?
Again, I'll report back if mine leaks.
Dan.
Dan J
Post  xschop on Wed Dec 01, 2010 9:46 am
I still have never seen or heard of confirmation that the S10 TO bearing has the same height dimensions and stroke length from top to bottom as the C5 TO bearing. By default the S10 TO bearing should have the same catch mechanism and it should install compressed against the PP splines just like the C5 TO bearing.
Got It
Post  968gene on Thu Dec 02, 2010 2:03 pm
Mailman delivered my shim today. Thanks!
968gene
