Shift Linkage Rubbing Against Gas Tank
I just installed a new 944 Turbo transmission into my NA, LS1 powered 944. Everything went smoothly until I went to connect the shifter and it wouldn't slide in. Then I noticed that the top of the shift linkage is rubbing on the heat shield of the gas tank. I have the shift linkage from the NA transmission and it looks identical. Maybe I reinstalled it wrong? If anyone has advice let me know! I will attach a pictures below.
Matthew- Posts : 2
Re: Shift Linkage Rubbing Against Gas Tank
Matthew wrote: Maybe I reinstalled it wrong? If anyone has advice let me know! I will attach a pictures below.
Matthew...it is not clear from your photos but you may have attached the linkage incorrectly.
Take a look at the pics in my thread and see if they help you identify something different.
TA Rehab Complete
TA Installation
Hopefully this helps.
Raymond-P- Posts : 385
I agree with Raymond,
Looks as if you have the short arm you're pointing to in the second picture, leaning the wrong way. If you're looking the the trans from behind, that arm is pointing to the 2 o'clock position... it should be at 10 o'clock. That will pull the attached crosspiece (also attached to the top right of trans case) down and it should fit.
Good luck!
Good luck!
Theer- Posts : 1
I figured it out, the small white piece in the middle of the linkage was installed upside down. Whoever I bought it from must have reversed it at some point. Thanks for the help all!
Matthew- Posts : 2
Yesterday at 8:32 am by Rob44
