Ealoken 951 project ( 07k next )
Hello folks.
I have modified my for for 5 years, here is where i started.
After 5 years, the list is:
Engine.
2.5 LA Sleeved block
HPO Rods
Wiseco pistons
Ported head ( 269cfm on 12mm lift )
Catcam big camshaft
GT3071 Turbo
ECU Master classic
60-2 trigger
ATI damper
Titan camshaft wheel
Custom hub crank
Oilfilter relocated
New oilcooler setup
custom intercooler
3"pipes
4" airfilter
44mm Tial WG
3" exhaust, all v-band
Drivetrain
Sachs motorsport clutch
Quaife diff
Chromolly driveshafts
Brakes
996TT Front calipers
350mm gt3 disc
996TT rear calipers
332mm gt2 disc ( 993 )
Suspension
30/19mm swaybars
LR Billet swaybar mount in front
KW Clubsports
Body
GTP headlights
3 pc carbon wing from DRS Development
CCW 18" wheels
Interiour
Sparco seats
Schroth 4pt belt
Momo steeringwheel
rear seat delete
Heigo half rollcage
Engine.
HPO Rods
Wiseco pistons
Catcam big camshaft
GT3071 Turbo
ECU Master classic
60-2 trigger
ATI damper
Custom hub crank
Oilfilter relocated
New oilcooler setup
custom intercooler
3"pipes
4" airfilter
44mm Tial WG
Drivetrain
Quaife diff
Brakes
350mm gt3 disc
996TT rear calipers
Suspension
30/19mm swaybars
KW Clubsports
Body
GTP headlights
CCW 18" wheels
Interiour
Sparco seats
Schroth 4pt belt
Momo steeringwheel
rear seat delete
Heigo half rollcage
Ealoken- Posts : 3
Re: Ealoken 951 project ( 07k next )
Next on the list, is a 07k Swap.
H-rods
Forged pistons
Catcam cams
7500rpm valvetrain
GTX3576G2 turbo
2plate clutch
01e 6 speed gearbox
H-rods
Forged pistons
Catcam cams
7500rpm valvetrain
GTX3576G2 turbo
2plate clutch
01e 6 speed gearbox
Ealoken- Posts : 3
Why the 01e 6 speed gearbox?
Jotronic- Posts : 1
Because it can handle 600 HP, better gear ratios and it's a 6 speedJotronic wrote:Why the 01e 6 speed gearbox?
Ealoken- Posts : 3
» Turbo Transaxle wanted
