aor into n/a car
aor into n/a car
ok, now that my aor shift issue is resolved its onto the next! can i use the two n/a mounts on the aor? as there is no provision on the n/a to use single mount, the aor has one bolt hole missing on the r/h side but i could make an adapter plate to remedy this i think, seems strange the low power car has 2 mounts but the turbo has one!, how has everyone else done it?
ex-pat mike- Posts : 6
Re: aor into n/a car
Sounds like you have an early car (pre 85.5). Those cars used two mounts. Later 944's used a single mount. Typically you can just install the two mounts to a later trans, as early and late transaxles used the same case.. Not positive on the aor, but imagine its still the same case as the rest , so should still have the same mounting provisions.
Leva- Posts : 82
Having done the same trans swap on an early 944, I welded an extension to the original mount to reach another bolt hole. Works great.
Porsche went to a single mount on the later cars due to vibration and noise issues with the 2 piece mounts.
thats good to know! i will add to original mounts then, i was going to also fill the voids with urethane to strengthen them a little too, thanks for the help i appreciate it!
