948 swaps in New Jersey
Kinda like the title says...any swaps in New Jersey?
TIA
TIA
nphd2000- Posts : 26
bell housing to block question
So i have a c5 1 piece auto bell housing, I bought a 1/4" block spacer and my block is an iron block 5.3 from an 04 Tahoe. All 3 parts have a different amount of mounting holes. It appears that only 5 holes line up with all 3 parts. 2 on each side by the dowel pins and 1 about half way up on the drivers side. Is this normal? How many does your have?
TIA
TIA
Re: 948 swaps in New Jersey
I'm in NJ with an 88 turbo swapped with an LS3. I have the 2 piece bellhousing so I can't offer much support, but I will say that this forum has all the information you need, it can just be a bit hard to find. Where did you get your conversion parts from?
The FB group has other info as well. I have a thread on here documenting my build (not sure if it will help you)
tannerhwilson- Posts : 21
build thread
Tanner,
Where is your build thread? I'll certainly take a look at it. I purchased some of the parts thru Kent who has been very helpful. Slowly collecting the rest and trying to fabricate some on my own. I'll check out the facebook group as well. Do you have DBC or DBW? Where in NJ are you located...North South Central?
https://944hybrids.forumotion.com/t3346-ls3-conversion
here's my thread^ pics might be dead I have DBW
I've PMd you
I've PMd you
