Mon Jul 08, 2013 5:56 pm by Admin
How much oil??
How much oil??
I’m using a TPC oil pan. How many quarts of oil should I be using?
C4924S- Posts : 53
Re: How much oil??
C4924S wrote:I’m using a TPC oil pan. How many quarts of oil should I be using?
If you are using the oil filter on the engine, then it's 6 quarts. If you are using a remote oil filter, then it could be as much as 7 quarts depending on how long the oils lines are. If you have an oil cooler as well, then that adds more.
Simplest way to check, is fill with 6 quarts. Start the engine for a minute to get the oil circulated through everything. Shut the engine off and then check the dipstick. Fill as needed to get to the full mark.
Re: How much oil??
I do have the filter on the engine/pan.
No oil cooler. But when I do add 6 quarts the dipstick still says to add more
C4924S- Posts : 53
Re: How much oil??
Do you have the GM dipstick, or is it an aftermarket?
Re: How much oil??
I need to ask Kent at TPC to be sure. I was thinking 6 quarts, but maybe it is 7.
Re: How much oil??
I know the moroso pan online says it takes 7q
C4924S- Posts : 53
Re: How much oil??
Is the oil on the dipstick at all?
Re: How much oil??
I talked to Kent and he verified 6 quarts. So I would suggest getting an F body dipstick and tube. The vette may be different due to the pan they use. I wouldn't think so, but not sure.
Re: How much oil??
6 litres into the pan (about 6 quarts) with a TPC pan and F-Body tube and dipstick gets me to the top mark. There’s more oil in the system since I have a remote filter and cooler, but if I empty the pan and fill it 6 litres is the amount to hit the top mark on the dipstick.
chrenan- Posts : 203
Yesterday at 5:06 pm by Rob44
Wed May 01, 2024 10:32 am by Rob44
Tue Apr 30, 2024 10:28 am by JW1970
Tue Apr 30, 2024 12:36 am by zenon
Tue Apr 30, 2024 12:24 am by zenon
Sun Apr 28, 2024 11:38 am by SpeedRacer11
Sun Apr 28, 2024 2:00 am by Raymond-P
Sun Apr 28, 2024 1:09 am by Raymond-P
Fri Apr 26, 2024 5:30 pm by ThomasJoseph315
Mon Apr 15, 2024 8:59 pm by JW1970
