What is VSS?
What is VSS?
Im just curious what is the vss sensor for the ls swap for? I know where it goes but what is the purpose of it, what does it control in the PCM?
C4924S- Posts : 53
Re: What is VSS?
C4924S wrote:Im just curious what is the vss sensor for the ls swap for? I know where it goes but what is the purpose of it, what does it control in the PCM?
VSS or vehicle speed sensor, is what tells the ecu how fast you are going. This helps in part throttle and stop and go type traffic. Especially good for decel when you are coming to a stop. It will let the ecu know to keep the engine from surging and/or dying. Most track cars don't use it. I advise it to be used on street cars.
Yesterday at 8:32 am by Rob44
