What route are you using for the battery charging wire from the generator?
What route are you using for the battery charging wire from the generator? It goes from the back of the gen to the battery.
I pulled my steering rack to rebuild it, and with it gone I saw that the existing battery charging wire is routed through the header, and the header has chaffed it down to the copper.
There must be a better way to route it?
Also, what gauge, 6? 8?
Thanks!
Andy
Thanks!
Andy
acorad- Posts : 697
Re: What route are you using for the battery charging wire from the generator?
I route mine out to the frame and in front of the radiator to the other side, then to the main starter post where the battery cable attaches. I always use a 6ga wire. Kinda long, but nothing to rub through it that way.
Hotrodz of Dallas wrote:I route mine out to the frame and in front of the radiator to the other side, then to the main starter post where the battery cable attaches. I always use a 6ga wire. Kinda long, but nothing to rub through it that way.
Did not think of that route, thanks!
Andy
acorad- Posts : 697
» Newb Build in Asheville NC area LS1 5.7 into 944 S2
» battery choices / recomendations
» Techno Duck's LS1 conversion
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
