WHERE to put ECM?
WHERE to put ECM?
Hey all!
The conversion of my 87 944NA to LS1 power is proceeding, but I'm curious as to where you guys are mounting the ECM and TAC module (i've got drive by wire).
Using all Renegade Hybrids parts etc. including their stand alone harness.
SO...what say you lol Where are you mounting? This IS gonna be a street car not a racecar
Thanks!
Jim
Thanks!
Jim
vapistol- Posts : 3
Re: WHERE to put ECM?
Some pictures for you of where I mounted my ECM and auxiliary relays/fuses:
chrenan wrote:Made a little a bracket for the relays (fans and fuel pump) and fuses. It sits behind the glove box, the MEFI computer will hide under the passenger footwell floor board where the stock computer lived.
chrenan wrote:Placed the MEFI unit where the old DME and KLR control boxes used to live, under the kick plate floor board below the glove box. Plenty of space with the plugs attached, and room for the extra main harness cable to tuck in beside. A floor board covers it then the carpet attaches with Velcro over top, a nice elegant placement developed by Porsche. I started running a few wires, there's a few 12Volt switched connections that need to go here and to the relay bracket pictured in a post above, as well as full time 12Volt in and some out wires (fans, fuel pump, tach).
chrenan- Posts : 203
Thanks!
Thanks for all the pics!!
Gives me a lot of new ideas :-)
vapistol- Posts : 3
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
