Pilot bearing and adapter stuck... HELP!!!
[url=[You must be registered and logged in to see this image.]][You must be registered and logged in to see this image.][/url]Having an issue getting the outer circle of this bearing out to replace it... Also cant get the adapter out. Obviousy that would make t easier... It wont budge. Any suggestions?
zeusrotty- Posts : 444
Re: Pilot bearing and adapter stuck... HELP!!!
Rent a blind hole bearing puller from autozone/advance? Or you could try freezing/heating the bearing to get it to release from the adapter. If there is room you could try to cut the bearing careful not to cut the adapter, that should release pressure to get it out.
Saw something where they filled up all of the open volume inside the donut hole of the bearing and adaptor with axle grease.
Then take a short length of a piece of broomstick or something that fits just inside the bearing, and hold it there so it makes a pretty good seal with the inside of the bearing such that the grease is sort of contained inside the bearing/adaptor. And then whale on the stick with a sledge.
Supposedly the hydraulic pressure from the grease getting pushed in by the stick will force the bearing out.
Supposedly!
Andy
Supposedly!
Andy
acorad- Posts : 697
LS1 has a freeze plug behind the bearing, so that method is not advisable. It did work on old style blocks. Blind hole puller slide hammer and it will come out.acorad wrote:Saw something where they filled up all of the open volume inside the donut hole of the bearing and adaptor with axle grease.
Supposedly!
Andy
The bearing is seriously hardened steel. Wonder if a Dremel will go through it?
I was able to cut it out the Dremel. On to the next hurtle. Lol
» C5 Bellhousing Adapter Plates and Pilot Bearing Adapter Combo
» Anti Seize on LS1 Pilot Bearing Adapter?
» GM 3800 V6 swap
» GM 3800 V6 swap
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
