Mon Jul 08, 2013 5:56 pm by Admin
*SOLD* Lexus big brake swap kit
Hey guys, here's what I have for sale:
Early hubs (with splash screens) machined to fit Boxster S Rotors, new Boxster S Rotors, Lexus to early N/A spindle brake adapters, brake line with correct swap fittings, and fresh remanufactured LS430 Calipers. $450 + actual shipping from Coon Rapids MN, 55433
All you need to do is strip your cars brakes off: Remove the rubber line to the caliper, remove the caliper, remove the hub, remove the splash screen. Bolt on the splash screen provided, bolt on the hub (and tighten the lock), put the rotor on the hub, bolt the adapter to the spindle, bolt the caliper on the adapter, install the included swap kit brake lines x2. Bleed x2, done! Huge badass brakes from a top tier maker for a fraction of the cost of big reds or big blacks. PORH
15" rims will be too small for this setup. If you're running stock Fuchs or cookie cutters you'll need to size up to a bigger set of wheels.
Last edited by adam7e on Tue Jan 26, 2016 8:05 pm; edited 2 times in total (Reason for editing : Pricing error)
adam7e- Posts : 63
Re: *SOLD* Lexus big brake swap kit
don't suppose these are still available?
FrostedFlakeJake- Posts : 263
» Lexus BBK Big Brake Kit
» Cryo-treated 85.5 Hubs/Spindles for Boxster/Lexus swap
» 86 turbo LS1 swap Sold !
Yesterday at 5:06 pm by Rob44
Wed May 01, 2024 10:32 am by Rob44
Tue Apr 30, 2024 10:28 am by JW1970
Tue Apr 30, 2024 12:36 am by zenon
Tue Apr 30, 2024 12:24 am by zenon
Sun Apr 28, 2024 11:38 am by SpeedRacer11
Sun Apr 28, 2024 2:00 am by Raymond-P
Sun Apr 28, 2024 1:09 am by Raymond-P
Fri Apr 26, 2024 5:30 pm by ThomasJoseph315
Mon Apr 15, 2024 8:59 pm by JW1970
