» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Cryo-treated 85.5 Hubs/Spindles for Boxster/Lexus swap
Post  xschop on Sun Nov 08, 2009 10:50 am
Selling because I changed to Late offset hubs to run Tubo Twist 18’s without 1” spacers. Early offset (85.5- NOT HOLLOW) Spindles and Hubs……
Spindles and hubs have been Cryo-treated, then hubs machined on outer edge to accept and center 318mm Boxster S rotors.
Included are the Lexus LS430 4-pot (4x42) caliper adapters that fit over the Boxster S rotors with new hardware.
They have new inner and outer bearings installed and preload set at locknut with fresh Molybdenum-Graphite high-temp grease.
Next, the spindles have been drilled and precision reamed to accept 5/8” Bump-steer Drop Bolts (4130 Steel) and stronger 5/8” Heim joints (Heims are not included). This allows up to a 2 inch drop and is way stronger than what is on the market. I will be including the Tie-rod conversion adapters with these that let you bypass buying the expensive Porsche Tie rods.
USPS Priority shipped anywhere in the U.S. Just PM me, Rob
