Strut brace?
+4
zeusrotty
RobotMachines
8 posters
Strut brace?
1983 944 with a 1994 LT1, lowered, heavy springs up front and 28mm solid rear torsion bars. On the horrible bumpy streets of CT, I feel I need to stiffen the uni-body. Do you think some strut braces would make a noticeable difference? If so, any problem with these; ->Strut Brace<-
RobotMachines- Posts : 165
Re: Strut brace?
I just bought one from KLA. It's good for the price.
Re: Strut brace?
I installed that KLA brace as well, cleared the LS1 w/o subframe spacers. But I can't say that I've noticed a difference as so much of the car is transformed with the new power and sound.
Re: Strut brace?
I have a Racing Dynamics. When I added the Racers Edge camber plates I had to grind on it a little for clearance. It fits like a glove now.
zeusrotty- Posts : 444
Re: Strut brace?
RobotMachines wrote:1983 944 with a 1994 LT1, lowered, heavy springs up front and 28mm solid rear torsion bars. On the horrible bumpy streets of CT, I feel I need to stiffen the uni-body. Do you think some strut braces would make a noticeable difference? If so, any problem with these; ->Strut Brace<-
You just changed the rear shocks....hows the fronts?
Re: Strut brace?
944-LT1 wrote:RobotMachines wrote:1983 944 with a 1994 LT1, lowered, heavy springs up front and 28mm solid rear torsion bars. On the horrible bumpy streets of CT, I feel I need to stiffen the uni-body. Do you think some strut braces would make a noticeable difference? If so, any problem with these; ->Strut Brace<-
Thanks everyone for the thoughts on the subject. I'm inclined to try it out.
Hey appreciator-of-yellow-zip-ties , you know, I think I had replaced the fronts when I put the RH shorty springs in many many years ago and forgot what type I had bought. They seem fine but you know, I think they could be stiffer. I just tried to get under the car to see and now my knees are covered in garage floor crud, no way to look under there to see the make being so low and not wanting to lie completely in the crud.
You know, Paul was right way back before I did the torsion bars and that I should have gone with the 26mm not the 28. The back feels like it's ready for a smooth track and makes the front bounce more from the lack of torsion bar give. No way am I going to replace those torsion bars again though
EDIT: I could get some stiffer springs? What were the RH springs, 350lbs?
Re: Strut brace?
Yeah I think so.EDIT: I could get some stiffer springs? What were the RH springs, 350lbs?
You know youre gonna change those bars. Its gonna eat at you and eat at you.... Pauls gonna come in here and laugh at you.... better get started. Besides, the first time is always like that. Now you know exactly how to do it. It'd probably take half the time.
Those last three sentences apply to many different things! Yup.
Re: Strut brace?
No laughing or I told you so....snickering . I think the 25.5mm bars would be better suited to the RH front springs, which are weltmeister 250lb springs IIRC......That is the setup i have with the factory Koni shocks turned to full stiff all around.
I suspect that just an upper bar won't make a huge diff; combined with a lower bar on the A-arms could be a diff story though.
Re: Strut brace?
if you're gonna replace your front springs look into ground control coils. I don't have em but I have talked to few that do and they work very nice and you still run your own struts.
Im thinking of doing this with my konis since im not happy with my 250# LR ones.
Oso- Posts : 28
Re: Strut brace?
948 wrote:No laughing or I told you so....snickering . I think the 25.5mm bars would be better suited to the RH front springs, which are weltmeister 250lb springs IIRC......That is the setup i have with the factory Koni shocks turned to full stiff all around.
Interesting, thanks!
Top strut brace
I have (had) a KLA strut brace but with Hydroboost it's not going to fit because of the HB reservoir.
Any ideas? Anybody have a workaround bracket idea?
Re: Strut brace?
Can you flip it around? Im not sure if the hood would close though... Might be worth a shot
Strut brace
The Fluid reservoir iterferes either way you fit the brackets.
Re: Strut brace?
Maybe you could weld a spacer on the front of the bracket and use a longer bolt to move the bar forward the distance it needs to be? Do you have any pictures of your hydroboost system?
Strut brace
I mounted the HB unit on a flat plate and adjusted it with angle blocks to give 12 degrees nose up.
Problem was the hood touched the MC reservoir. I reduced the angle and the hood clears and now the brace bar should fit if I use spacers and longer bolts. Pics to follow when completed.
