Stock 944 NA Clutch and Pressure Plate capabilities.
I have come upon an interesting development in my swap. The stock 944 pressure plate bolts up directly to the flywheel for my 4g63.
This could greatly simplify my project, but i am concerned that the stock clutch and pp is not up to the task of handing the high revving 300+hp engine I am installing...
backpack09- Posts : 12
Re: Stock 944 NA Clutch and Pressure Plate capabilities.
Same number of teeth?
» 944 Clutch and Pressure plate
» flywhee/clutch/pressure plate
» LS1 SPEC Flywheel, Clutch & Pressure Plate Assembly
» Turbo Transaxle wanted
