Cooling Fan stopped working EmptyToday at 8:32 am by Rob44
» Adapter plate
Cooling Fan stopped working EmptyToday at 8:28 am by Rob44
Cooling Fan stopped working EmptyYesterday at 8:28 am by JW1970
» Parts availability for general maintenance?
Cooling Fan stopped working EmptyMon Apr 29, 2024 10:36 pm by zenon
» What coilover spring rates are you running with torsion bar removed?
Cooling Fan stopped working EmptyMon Apr 29, 2024 10:24 pm by zenon
Cooling Fan stopped working EmptySun Apr 28, 2024 9:38 am by SpeedRacer11
Cooling Fan stopped working EmptySun Apr 28, 2024 12:00 am by Raymond-P
Cooling Fan stopped working EmptySat Apr 27, 2024 11:09 pm by Raymond-P
» Rear coilover suspension setup
Cooling Fan stopped working EmptyFri Apr 26, 2024 3:30 pm by ThomasJoseph315
Cooling Fan stopped working EmptyMon Apr 15, 2024 6:59 pm by JW1970
May 2024
6789101112
13141516171819
20212223242526
2728293031
Page 1 of 2 1, 2  Next
Cooling Fan stopped working Empty Cooling Fan stopped working
Post  acorad Thu Mar 31, 2011 5:15 pm
My (single) cooling fan stopped working yesterday, and of course yesterday was the first hot day of the year!
I've never really messed around much with electricals before.
Anyway, the 2 fan fuses (#10 & 15) seem fine, not sure which one is in-line with my fan.
Not having built the car, near as I can tell it looks to me like the fan plug has power to it from the harness (2 power wires), a power wire from the plug to the fan motor, and the wire from the thermo switch in the radiator to the plug.
I assume the thermo switch controls whether power gets to the fan motor through the fan plug based on the radiator temp, and it does this whether or not the engine is on, as the fan used to always run for a minute or two after shutting the engine off.
I don't know if the wiring for the fan goes through one of the OEM slow speed resistors or not, but I doubt it as I never noticed two different fan speeds, although I really wasn't paying much attention to it until now.
Anyway, does this sound like the thermo switch is shot?
The switch looks like 1/2" thread, I assume I can replace it with any 1/2" thermo switch?
The temps never got much more than a hair above the 1st hash mark on the temp gauge before, which I've read is the 80C mark, so I'd need what, a 85C thermo switch? 83C? Higher?
Let me know what you think!
Cooling Fan stopped working Empty Re: Cooling Fan stopped working
Post  acorad Thu Mar 31, 2011 10:15 pm
Ok, the car's builder said it's just a straight power line from the battery to the plug of the fan and the thermo switch completes the ground. There is supposed to be an in-line fuse too, that he thinks is probably burned out.
Post  acorad Fri Apr 01, 2011 12:26 pm
So it turns out that the fan plug is bad.
This plug has power in, power out, and the wire from the thermo switch in the radiator.
This is printed on the plug, MAS looks like the manufacturer:
MAS
REL40 12VDC
12V 30/40A
and also an elec diagram.
Any ideas where I can find another plug?
Post  spence Fri Apr 01, 2011 12:54 pm
Sounds like its just a normal relay... Does it look like this? [You must be registered and logged in to see this image.]
Post  spence Fri Apr 01, 2011 12:56 pm
You can get those at any eletronic stores that install car stereos ect.
Those relays are known to blow when used with fans because they can't handle the voltage spike that goes thru them.
You should try and find a 50amp relay
Post  acorad Fri Apr 01, 2011 12:59 pm
That's the one spence! I'll look for a 50A.
Thanks!
Post  spence Fri Apr 01, 2011 1:12 pm
no problem... I think other people might even be using a 75amp relay to run fans
Post  acorad Fri Apr 01, 2011 1:16 pm
Thanks, as I said above, I've never messed around with auto electrics much before. The inline fuse is 30A and it didn't blow, why do you suppose the relay fried out?
Post  spence Fri Apr 01, 2011 1:21 pm
As i understand it the voltage spike happens only when the fans first come on and only for a couple milliseconds and it wouldn't be long enough to blow the fuse. I'm no electrical guru either... I'm only going by what I have read.
Post  acorad Fri Apr 01, 2011 1:26 pm
Thanks spence.
Post  acorad Fri Apr 01, 2011 1:54 pm
Actually, the relay in my car has 5 prongs, not 3. Two prongs are connected to the power from the battery, one is power out to the fan, one is connected to the thermo switch in the radiator, and the 5th one is not used.
I don't know what the difference is between 5 and 3 prong relays.
Could I use a 3 prong instead? One power in, one power out, and one to thermo switch?
Post  spence Fri Apr 01, 2011 2:16 pm
The 5 prong relays are common. The 75amp relays have 4 prongs which would work for you. Then you'd never have to worry about it blowing again.
And you'd wire it like this
Post  acorad Fri Apr 01, 2011 3:33 pm
Thanks spence, I've been googling around and reading up on them, pretty simple stuff, really.
Anyway, I'm calling all the Pep Boys/Autozone-type places near me, but they don't seem to have generic relays, they're all asking me for make and model or part numbers.
I'm still searching...
Post  Dawgz83948 Fri Apr 01, 2011 4:17 pm
acorad wrote:Thanks spence, I've been googling around and reading up on them, pretty simple stuff, really.
They do have generic 25 or 30 amp relays. Ask for fog light relays. I forget where you live but I'd give you one as I bought a few extra to keep around. I'll be in Lodi tomorrow for traffic school, and am in the Pleasanton during the week.
Post  acorad Fri Apr 01, 2011 4:22 pm
Thanks Dawg, I can find plenty of 30's but I'd like a higher amp like 70 so I don't have to bother with this again. My local Fry's carries 70's but they're not in stock, Radioshack only has 30's.
Post  Dawgz83948 Fri Apr 01, 2011 4:41 pm
acorad wrote:Thanks Dawg, I can find plenty of 30's but I'd like a higher amp like 70 so I don't have to bother with this again. My local Fry's carries 70's but they're not in stock, Radioshack only has 30's.
I had to order mine off ebay. No local sources had them. I used two 75 amp.
1 day ups to Cali.
The big secret is if they have RH's radiator, get the damn relay OFF the radiator. They don't like water.
Post  acorad Fri Apr 01, 2011 5:14 pm
1 day ups to Cali.
Yup, RH radiator and it's mounted on the lower fan.
I order stuff from McMaster-Carr for my biz all the time. Just did a quick search and yup they have relays.
I ordered a Weatherproof Five Pin High DC Inrush Current Relay w/mounting bracket, also called "automotive relay."
Supposedly it can handle a high-inrush current of 150A and has a mechanical life of 1 million cycles.
Less than $9, part #9672K44, and it'll be here on Monday.
Sounds like it should work, no?
Post  Dawgz83948 Fri Apr 01, 2011 5:37 pm
Yup. But I highly recommend moving the relay off the radiator. It had no business being there in the first place.
1 day ups to Cali.
Post  acorad Fri Apr 01, 2011 9:35 pm
Dawgz83948 wrote:Yup. But I highly recommend moving the relay off the radiator. It had no business being there in the first place.
Will do.
Post  944-LT1 Fri Apr 01, 2011 10:41 pm
I have the RH radiator as well and the relay was also mounted to the lower fan mount.....It blew and caused me alot of grief. Absolutely stupid place to have a relay. I replaced it with a 70 amp tyco relay and have never had a problem (with the relay) since.......But then, the cheap crap RH fan that came with the radiator failed and this wasnt a failure like it doesnt work but the kind where it drains your battery and the magnets of the motor fall out. Horrible.
Look at replacing the RH fan when you get a chance.
Post  acorad Fri Apr 01, 2011 10:51 pm
Thanks LT1. The radiator has also now sprung a leak. The rad in my Durango has 180k+ trouble-free miles on it, the rad in this car has less than 10k miles on it. I guess my next step is to research the hell out of radiators!
Post  944-LT1 Sat Apr 02, 2011 4:00 am
Now THAT sucks. RH charged me a grand for the radiator set-up so a leak at 10K is absurd.
I bet you could send it back to ron davis to have it fixed; atleast for a small fee. Question
Post  acorad Sat Apr 02, 2011 8:59 am
944-LT1 wrote:Now THAT sucks. RH charged me a grand for the radiator set-up so a leak at 10K is absurd.
Good point, I'll contact them.
Post  Dawgz83948 Sun Apr 03, 2011 11:14 am
I took mine to a local radiator shop and they fixed it up for $25. Place I used was Modesto Auto Electric.
Post  acorad Wed Apr 27, 2011 11:55 am
Well, the radiator is at the shop getting repaired. Turns out some of the tube-to-header joints were leaking, and the shop is expoxieing them. And also preventively epoxieing most of the others, just in case.
I called Ron Davis and they said to bring it to rad shop and have it epoxied. They said the rads leak if they're not mounted correctly, and that they stopped making rads for RH because of these types of problems.
I called RH and they said I could either ship the rad to them, and they'd charge me whatever their rad shop charged them to fix it, or just find a local shop to fix it. They also recommended epoxieing it. They also said it has to be mounted correctly or it will leak.
I had a long talk with them about how to mount it correctly and I'm pretty sure it was mounted correctly (gently held w/in the soft rubber nubs of the mount).
Anyway, that's what's going on.
