944Hybrids
Welcome to our forum.
Cooling Fan stopped working
Page 1 of 3 • Share •
Page 1 of 3 • 1, 2, 3
My (single) cooling fan stopped working yesterday, and of course yesterday was the first hot day of the year!
I've never really messed around much with electricals before.
Anyway, the 2 fan fuses (#10 & 15) seem fine, not sure which one is in-line with my fan.
Not having built the car, near as I can tell it looks to me like the fan plug has power to it from the harness (2 power wires), a power wire from the plug to the fan motor, and the wire from the thermo switch in the radiator to the plug.
I assume the thermo switch controls whether power gets to the fan motor through the fan plug based on the radiator temp, and it does this whether or not the engine is on, as the fan used to always run for a minute or two after shutting the engine off.
I don't know if the wiring for the fan goes through one of the OEM slow speed resistors or not, but I doubt it as I never noticed two different fan speeds, although I really wasn't paying much attention to it until now.
Anyway, does this sound like the thermo switch is shot?
The switch looks like 1/2" thread, I assume I can replace it with any 1/2" thermo switch?
The temps never got much more than a hair above the 1st hash mark on the temp gauge before, which I've read is the 80C mark, so I'd need what, a 85C thermo switch? 83C? Higher?
Let me know what you think!
acorad- Posts: 394
Re: Cooling Fan stopped working
Ok, the car's builder said it's just a straight power line from the battery to the plug of the fan and the thermo switch completes the ground. There is supposed to be an in-line fuse too, that he thinks is probably burned out.
acorad- Posts: 394
So it turns out that the fan plug is bad.
This plug has power in, power out, and the wire from the thermo switch in the radiator.
This is printed on the plug, MAS looks like the manufacturer:
MAS
REL40 12VDC
12V 30/40A
and also an elec diagram.
Any ideas where I can find another plug?
MAS
REL40 12VDC
12V 30/40A
acorad- Posts: 394
Sounds like its just a normal relay... Does it look like this? [You must be registered and logged in to see this image.]
spence- Posts: 326
You can get those at any eletronic stores that install car stereos ect.
Those relays are known to blow when used with fans because they can't handle the voltage spike that goes thru them.
You should try and find a 50amp relay
spence- Posts: 326
That's the one spence! I'll look for a 50A.
Thanks!
Thanks!
acorad- Posts: 394
no problem... I think other people might even be using a 75amp relay to run fans
spence- Posts: 326
Thanks, as I said above, I've never messed around with auto electrics much before. The inline fuse is 30A and it didn't blow, why do you suppose the relay fried out?
acorad- Posts: 394
As i understand it the voltage spike happens only when the fans first come on and only for a couple milliseconds and it wouldn't be long enough to blow the fuse. I'm no electrical guru either... I'm only going by what I have read.
spence- Posts: 326
Thanks spence.
acorad- Posts: 394
Actually, the relay in my car has 5 prongs, not 3. Two prongs are connected to the power from the battery, one is power out to the fan, one is connected to the thermo switch in the radiator, and the 5th one is not used.
I don't know what the difference is between 5 and 3 prong relays.
Could I use a 3 prong instead? One power in, one power out, and one to thermo switch?
acorad- Posts: 394
The 5 prong relays are common. The 75amp relays have 4 prongs which would work for you. Then you'd never have to worry about it blowing again.
And you'd wire it like this
spence- Posts: 326
Thanks spence, I've been googling around and reading up on them, pretty simple stuff, really.
Anyway, I'm calling all the Pep Boys/Autozone-type places near me, but they don't seem to have generic relays, they're all asking me for make and model or part numbers.
I'm still searching...
acorad- Posts: 394
acorad wrote:Thanks spence, I've been googling around and reading up on them, pretty simple stuff, really.
They do have generic 25 or 30 amp relays. Ask for fog light relays. I forget where you live but I'd give you one as I bought a few extra to keep around. I'll be in Lodi tomorrow for traffic school, and am in the Pleasanton during the week.
Dawgz83948- Posts: 597
Thanks Dawg, I can find plenty of 30's but I'd like a higher amp like 70 so I don't have to bother with this again. My local Fry's carries 70's but they're not in stock, Radioshack only has 30's.
acorad- Posts: 394
Similar topics» Still working web flood
» Amazing Beautiful Official Working Babe Showing Her Beuty On
» moonroof and rear roof stopped working
» help sub stopped working!! (fixed)
» Cooling Fan stopped working
Page 1 of 3
» HELP . . . Electrical gremlin
» Rich's LS powered 944 track car
» First Time Swap 85 Porsche 944 to LS6
» Oil and steering cooler options
» selling conversion parts due to new baby
» Strut brace?
» What LS Exhaust Manifolds / Headers
» building a 1983 948 on a budget - pointers?
» To " badge or not to badge "
