» Blowing A Racing Engine (Dropped A Valve)
OK Brain Trust Need some help EmptyYesterday at 9:41 pm by MotoRider42HC
» 944 LM4 5.3 swap for sale
OK Brain Trust Need some help EmptyYesterday at 2:35 pm by secheltguy
» Adapt VSS to early car mechanical speedometer?
OK Brain Trust Need some help EmptyYesterday at 1:59 pm by Hey_Allen
» 88 951 LS1 TRACK CAR FOR SALE
OK Brain Trust Need some help EmptyYesterday at 9:45 am by Dawgz83948
» Turbo Transaxle NA swap (Non-lsd to LSD)
OK Brain Trust Need some help EmptyWed Nov 06, 2024 2:01 pm by Krowdy
» Any Custom Exhaust Installers Tri-State Area?
OK Brain Trust Need some help EmptySat Nov 02, 2024 10:13 am by 87roadracer
» What coilover spring rates are you running with torsion bar removed?
OK Brain Trust Need some help EmptySat Nov 02, 2024 9:24 am by haroldk
» 951 Transaxles For Sale
OK Brain Trust Need some help EmptyTue Oct 08, 2024 11:04 pm by Andy87944NA
» Modified 944 Front Suspension - Complete
OK Brain Trust Need some help EmptyMon Oct 07, 2024 9:51 am by 944_GASM
» Monster wide body LT-1 for sale
OK Brain Trust Need some help EmptySun Sep 29, 2024 7:23 am by 944-LT1
November 2024
OK Brain Trust Need some help Empty OK Brain Trust Need some help
Post  944v8inDFW Tue Aug 17, 2010 10:18 am
Looking for a relay that does the following...
Normally closed position when powered up
With a push button / momentary contact it opens the circuit until either power is removed (key off) or the push button is pushed again.
Could be more then 1 relay or even a little logic board that can control a relay.
944v8inDFW
OK Brain Trust Need some help Empty Re: OK Brain Trust Need some help
Post  948 Tue Aug 17, 2010 11:52 am
I'll try, though my electronics is a little rusty...
The simplest solution is to find a latching relay, though most are in the 5v, 90v and 250v range; 12v ones do exist but I hav enever used them so I can't comment on their specs. Call digikey for a start.
I would use a traditional 12v 30 amp relay and a flip flop IC; for this to work you will need to also add a switch debouncing circuit to the push button output.
These are all quite easy to wire up and the parts required can be found easily.
http://www.hobbyprojects.com/flip_flop/switch_debouncing.html
http://electronicsworld.tripod.com/designimages/designckt1.html
http://www.hobbyprojects.com/F/Flip_flop_Circuits.html
Post  948 Tue Aug 17, 2010 11:53 am
Oh and if you want to get relay crazy...
http://www.the12volt.com/relays/page5.asp#lsp
