» Blowing A Racing Engine (Dropped A Valve)
Security System EmptyYesterday at 9:41 pm by MotoRider42HC
» 944 LM4 5.3 swap for sale
Security System EmptyYesterday at 2:35 pm by secheltguy
» Adapt VSS to early car mechanical speedometer?
Security System EmptyYesterday at 1:59 pm by Hey_Allen
» 88 951 LS1 TRACK CAR FOR SALE
Security System EmptyYesterday at 9:45 am by Dawgz83948
» Turbo Transaxle NA swap (Non-lsd to LSD)
Security System EmptyWed Nov 06, 2024 2:01 pm by Krowdy
» Any Custom Exhaust Installers Tri-State Area?
Security System EmptySat Nov 02, 2024 10:13 am by 87roadracer
» What coilover spring rates are you running with torsion bar removed?
Security System EmptySat Nov 02, 2024 9:24 am by haroldk
» 951 Transaxles For Sale
Security System EmptyTue Oct 08, 2024 11:04 pm by Andy87944NA
» Modified 944 Front Suspension - Complete
Security System EmptyMon Oct 07, 2024 9:51 am by 944_GASM
» Monster wide body LT-1 for sale
Security System EmptySun Sep 29, 2024 7:23 am by 944-LT1
November 2024
Security System
Security System Empty Security System
Post  cfgioja Sun Feb 07, 2010 7:13 pm
So I picked up an 86 turbo, I tried to trun the key to check all the electrics and the alarm goes off. I have not been able to figure out how to keep it from going off. I tried putting a key in the alarm spot on the outside of the car, but the guy lost the orignal so this key doesn't fit into that one, or the actual lock is busted.
Any ideas on how to keep it off?
Security System Empty Re: Security System
Post  Admin Sun Feb 07, 2010 8:19 pm
pull the black box next to the ecu that say's alarm on it. That will keep it from going off at least till you get a good key or by pass it.
Post  Arthropraxis Sun Feb 07, 2010 8:46 pm
clarks garage has a page on bypassing the factory alarm system.
http://www.clarks-garage.com/
Post  cfgioja Sun Feb 07, 2010 8:51 pm
I did not know about Clarks page thanks. It looks like it has everything I will need.
Post  Arthropraxis Sun Feb 07, 2010 9:54 pm
You can bypass it short term. If you want the alarm to work with the ignition key there is an option. I think I found this on rennlist at some point. On the drivers side door jam take out the plastic vent, unscrew the collar around the lock for the alarm( the keyhole on the outside), pull the locking mechanism out, pry/hacksaw the endplate off so the cylinder will slide out, insert your key and try to turn it, remove the brass pins that don't allow the key to turn. Reassemble once the key works in the lock. Then unbypass and try to see if the alarm works. I am sure if you search you can get more clear directions.
Post  cfgioja Tue Feb 09, 2010 1:48 pm
Security System Alarm_10
So upon further investegation into the 86, I find this alarm box tied to a shock sensor, proximity sensor and a kill switch. I attempted the Factory Alarm bypass as stated in Clark's Garage, also I shut off the after market setup but the Horn sounds when sounds when I turn the key to on. I am going to again once I find a couple of connectors to use on the wire.
But It looks like I will be doing some old fashion wire diagram refrences to this jumble of wiring. Any ideas?
Post  Dawgz83948 Tue Feb 09, 2010 2:10 pm
That does not look factory.
Post  cfgioja Tue Feb 09, 2010 2:22 pm
No that is not, the factory one is where it is suppose to be. This one is under the steering wheel. Ya fun.
Post  Admin Tue Feb 09, 2010 3:24 pm
That's an old "CODE" (brand name) alarm, It's POS in every way. follow each wire and disconnect it. Get it all out. The 2 white wires(one has a red stripe) go to your starter wire , they will need to br connected together. I would follow them back to the factory wiring and remove as much aftermarket BS as possible. Looks like a piss pour install to start with. If the horn (or is it the siren from the code alarm) honks when you turn the key, make sure you a fully charged battery on the car. Low voltage will sometimes set everything of.
Post  cfgioja Tue Feb 09, 2010 5:28 pm
Thanks, I didnt even know what kind of alarm it was, they took all the stickers off.
I plan on taking it all out, I have to let it warm up first. From there I up to figure out something.
I am using a red top that I had hooked up in my other 944. By the time the swap is complete, The factory alarm is useless is it not?
Post  Admin Tue Feb 09, 2010 7:23 pm
If the factory alarm actually works then , no it's not useless. I have never seen one that did work though.
Post  cfgioja Tue Feb 09, 2010 7:30 pm
Ok, well when it warms up out here, I hope to strip the harness back to stock. Thanks for the advice
Post  Admin Tue Feb 09, 2010 7:40 pm
NO problem, I spent about 8 years of my life installing auto electronics. That brand of alarm was some of the very first ones, that I installed back in the day.
