wilwood clutch master
+3
Raymond-P
Hotrodz of Dallas
ex-pat mike
7 posters
just getting all parts ordered for ls1 swap and as my oem clutch master is toast i thought i would get a wilwood 13/16 or 7/8 master, but all the recommended ones seem to have the mounting holes in north south pattern and the porsche is east west mounting, do i need to make adaptor or just drill firewall to suit?
ex-pat mike- Posts : 10
Re: wilwood clutch master
TPC has clutch masters made by tilton that are modified for the 944. Wilwood and tilton do not make one in the correct orientation as is. My experience with the wilwood that are modified to fit don't last long. I prefer the Tilton.
Hotrodz of Dallas- Posts : 619
ex-pat mike likes this post
Ex-Pat Mike,
I had great success with the TPC Tilton unit and installation kit. Below is a link to my installation adventure:
Raymond-P- Posts : 388
thanks ray, for some reason i thought i had seen the wilwood mc used in the vertical hole position so needed an adaptor, all clear now!
Last edited by ex-pat mike on Tue Jun 11, 2024 7:29 am; edited 1 time in total (Reason for editing : spelling)
There used to be an aluminum bolt-on adapter deal to change the bolt pattern for a standard Wilwood or Tilton master. This was years back, xschop maybe?
Rich L.- Posts : 929
Heck, I installed the Wilwood with no modification. It works without any issue.
In the kit it is suppled with a fitting that allows you to pipe it right to the factory res. It's easy. Do it.
Michael B.- Posts : 84
Michael B. and ex-pat mike like this post
I used the Wilson’s for my system. Slight modification but no issues whatsoever in years.
jess2suityou- Posts : 19
If you guys want I can measure out the mount that xschop built for his car. I am the newest owner of it
D3mon948- Posts : 3
![-](https://2img.net/i/empty.gif)
» Wilwood clutch master died WAY too soon!
» BNIB modded Wilwood 13/16" clutch master and pushrod
» WTB: LS2 Intake Manifold/Rails/Inj; Tilton/Wilwood short master cylinders
» Bellhousing removal
» Anyone running aftermarket or improved cv axles?
» Spec Stage1 Pressure Plate
» Rear suspension?
» Used & Repairable Smoked Tint Saratoga Top
» wilwood clutch master
» Air intake LS1
