Need confirmation on A/C condenser plumbing
I purchased the TPC A/C kit with compressor, condenser and brackets and I am now plumbing the system. I labeled the inlet at the middle fitting and outlet of the condenser at the bottom fitting when I installed it. Now that I am ready to make the hoses to connect everything, I think I labeled the inlet and outlet incorrectly. The TPC condenser has a #8 fitting on the bottom and I believe that should be the inlet from the compressor and the fitting in the middle of the condenser pointing down is a #6 fitting. The #6 fitting should be the outlet of the condenser to the dryer. This is the opposite of the original system I think. Am I correct that the inlet is the #8 fitting and the outlet is the #6 fitting?
gwistrup- Posts : 113
Re: Need confirmation on A/C condenser plumbing
Check out this link... I think it will help. I've diagramed my original system and the new system. Hose sizes are provided.
https://944hybrids.forumotion.com/t2585p175-ray-s-1987-944-ls1-build-swap#40341
Raymond-P- Posts : 385
RE; A/C plumbing
Raymond, the picture on the diagram shows the outlet on the bottom of the image of the condenser. The description shows #8 to #8 and #6 to #6. I should have looked at the picture more closely. Thanks again, Gil
Today at 6:44 pm by Raindoc
» Turbo Transaxle wanted
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
