» Weird loud vibration from clutch
New Owner of someone else's start EmptyFri Sep 22, 2023 10:37 pm by acorad
» Big Reds upgrade
New Owner of someone else's start EmptyFri Sep 22, 2023 5:26 pm by Rond948
» Manual brakes "pad" recommendations
New Owner of someone else's start EmptyMon Sep 18, 2023 11:42 pm by Rond948
New Owner of someone else's start EmptySun Sep 17, 2023 10:22 am by 89EFhatch
» build issues continue
New Owner of someone else's start EmptySun Sep 17, 2023 12:00 am by Porsche951toLS3
New Owner of someone else's start EmptyFri Sep 15, 2023 2:15 am by Raymond-P
» DBW gas pedal bracket solutions for an S2?
New Owner of someone else's start EmptyThu Sep 14, 2023 10:06 am by dcoutofstep
» LT1 cooling system expansion tank
New Owner of someone else's start EmptyWed Sep 13, 2023 10:28 am by quarterflash
New Owner of someone else's start EmptySun Sep 10, 2023 8:22 am by chrenan
New Owner of someone else's start EmptySat Sep 09, 2023 3:09 pm by Raymond-P
October 2023
New Owner of someone else's start Empty New Owner of someone else's start
Post  CobraShark Mon Jul 11, 2022 8:49 pm
Hi All,
New member here. I bought a project start from someone else and the maker of some of the conversion parts will not help with instructions. So I am here because this seems a merry bunch of go getters and otherwise communicative group Cool
So far, I am tracking some bellhousing/cltuch/TBO potential issues that I may need moral support on. Potentially also need a 6spd conversion and I would rather send my money some where its appreciated if our resident expert is still pumping out parts.
Some photos of the starting point[You must be registered and logged in to see this image.]
CobraShark
New Owner of someone else's start Empty Re: New Owner of someone else's start
Post  CobraShark Mon Jul 11, 2022 8:50 pm
CobraShark
Post  CobraShark Mon Jul 11, 2022 8:51 pm
CobraShark
Post  CobraShark Mon Jul 11, 2022 8:53 pm
CobraShark
Post  CobraShark Mon Jul 11, 2022 8:54 pm
CobraShark
Post  CobraShark Fri Jul 15, 2022 7:30 am
Before I get too far down the "what does it have now path" here are some issues I am contending with:
- When they got the red car, it had the original 82 5pd LSD transmission
- They did need to replace the torque tube
- The motor was built and dyno run at 505 hp
SOOO one of my first contenders after I get the thing wired and running would be transmission choices. They set this car up as a racer buit I would set it up mostly as a street oriented car. I tend to lean towards a built auto for high horsepower but they spent a lot getting the shifter and torque tube set up.
Seems like the options are:
- Swap for a 86+ manual, would maybe be able to reuse the torque tube, axles, and shifter? ($4k??)
- Swap for a Z06 trans and modified torque tube??? ($4-6k???)
- Swap for built 928 4 sp Auto.... Do I need a new torque tube and axles again? Swap bellhousing and switch to torque converter?
Which transmission setup seems like to is the most power capable without going through crazy endeavors to make it work? The popular "other place vendors" want an arm and a leg for the conversion parts. I'm hoping our resident expert is still making parts. I hate to undue too many things that have been bought and installed by the previous owner... but the parts combo on it right now will destroy the transmission in a week.
Thx!
CobraShark
Post  948 Fri Aug 19, 2022 7:06 am
Torque is really the issue but i assume you have 400+ Lbft, so a change is needed.
I would go with a C5/6 transaxle; spares and aftermarket support are plentiful.
