Hydro boost without power steering
Wondering if anyone has used TPC’s hydro boost without a power rack. I just installed a manual rack and capped off the high pressure output from the hydro boost … I only started up and drove around the parking lot but it seemed like the pump was overheating. Wondering if there is too much restriction going into the hydro boost and back to reservoir without the additional output going to a rack.
rjarvis- Posts : 61
Re: Hydro boost without power steering
Don't run it like that, like you said you will overheat the fluid quickly. When it has no where to go, the relief valve opens and forces all that fluid through, heating it up.
You have to run that high pressure line back to the reservoir. It won't be under pressure, just think of it as another return line.
Today at 3:06 pm by Rob44
