» Blowing A Racing Engine (Dropped A Valve)
CEL MIL hook up EmptyYesterday at 9:41 pm by MotoRider42HC
» 944 LM4 5.3 swap for sale
CEL MIL hook up EmptyYesterday at 2:35 pm by secheltguy
» Adapt VSS to early car mechanical speedometer?
CEL MIL hook up EmptyYesterday at 1:59 pm by Hey_Allen
» 88 951 LS1 TRACK CAR FOR SALE
CEL MIL hook up EmptyYesterday at 9:45 am by Dawgz83948
» Turbo Transaxle NA swap (Non-lsd to LSD)
CEL MIL hook up EmptyWed Nov 06, 2024 2:01 pm by Krowdy
» Any Custom Exhaust Installers Tri-State Area?
CEL MIL hook up EmptySat Nov 02, 2024 10:13 am by 87roadracer
» What coilover spring rates are you running with torsion bar removed?
CEL MIL hook up EmptySat Nov 02, 2024 9:24 am by haroldk
» 951 Transaxles For Sale
CEL MIL hook up EmptyTue Oct 08, 2024 11:04 pm by Andy87944NA
» Modified 944 Front Suspension - Complete
CEL MIL hook up EmptyMon Oct 07, 2024 9:51 am by 944_GASM
» Monster wide body LT-1 for sale
CEL MIL hook up EmptySun Sep 29, 2024 7:23 am by 944-LT1
November 2024
CEL MIL hook up
CEL MIL hook up Empty CEL MIL hook up
Post  rooster Sun Aug 26, 2012 2:35 pm
*Full disclosure - I'm not the strongest when it comes to wiring.
I've been trying to figure out where to hook up the MIL signal from the LS1 PCM. I'd like to use the unused Check Engine light on the cluster. It looks like there are three bulbs that illuminate the CEL on the cluster and they correspond to pins #5 & #6 on connector "C" on the back of the cluster. Pin #5 is black with red stripe and according to the wiring diagram it terminates at a "welding point connection with field data" J19. I have no idea what that means. Pin #6 also goes to the CEL bulbs but there is no wire in connector "C" to tie into. Do I need to find a way to get a pin into position #6 so I can wire the MIL to it?
I thought this part would be easier.....
Thanks for any help you can provide.
-Rooster
rooster
CEL MIL hook up Empty Re: CEL MIL hook up
Post  spence Sun Aug 26, 2012 3:16 pm
I took the easy way out and wired the CEL into the brake fluid indicator wire in the engine bay. This will light up the (!) light. unfortunately, it will also light up the brake fluid light on the dash. The brake fluid light isnt that big of a light anyway. I know that's not what you asked.... Just another easy option.
Post  944convert Sun Aug 26, 2012 3:39 pm
and guessing...just take the 'brake fluid light' bulb out of the cluster panel if it bothers you
Post  spence Sun Aug 26, 2012 3:42 pm
ya, im real lazy; I left the bulb in... Smile
Post  rooster Sun Aug 26, 2012 4:23 pm
Thanks for the reply spence, I may do that if I cannot get the stock CEL light worked out. Since you brought up the ! light, I have all my power and ground wires hooked up at this point and when I turn the key to "on" the ! lights up already. I assume there are a number of things that are missing from the old engine that are causing the ! to light up. So how do I get it to turn off if I decide to wire up the MIL like you did?
rooster
Post  spence Sun Aug 26, 2012 6:08 pm
The (!) light is hooked up to a number of different things. The brake pad sensors, E brake, brake fluid and I think oil and coolant.
I only had to wire the brake pad senor wires together from what I remember (im not using the stock brakes); everything else was fine. You'll have to go around to each sensor and find out which one is tripping it.
When my key is "on" the (!) is lit up; I think thats normal. When the car is running it shuts off (unless it gets tripped)... Yours may be the same
Post  rooster Sun Aug 26, 2012 8:40 pm
That makes sense. Sorry for the ignorance, I've never driven this car it had a seized motor when I bought it. It's also been at least 10 years since I've owned another 944 and cannot remember what the dash lights all do. Thanks for the help.
-Rooster
rooster
