ECU Wiring
ECU Wiring
I know this topic has been hit a few times and I have read all the post but I have found some conflicting information so I just want to make sure I am doing this right. I am running a Microsquirt ECU so there's only a few wires. I will be using the DME relay- Fetch9 Solid State
Red- 12V Battery
Black- ECU Ground
Small Red- 12V Switched
Purple- Fuel Pump
Green- Tach
From my understanding leaving everything in there and accessing the 14pin connector in the engine bay driver side at the firewall these are the pins I need:
Pin 3- Use for 12v Switched
Pin 4- Use For Fuel Pump
Pin 6- Use For Oil Gauge
Pin 8 - Use For Coolant Warning
Pin 9- Use For Oil Warning
Pin 10- Use For Coolant Gauge
Tach will be attached to back of cluster
12v Battery to Battery
Ground I assume Engine or Battery Ground
Red- 12V Battery
Black- ECU Ground
Purple- Fuel Pump
Green- Tach
CyCloNe!- Posts : 33
Re: ECU Wiring
Looks correct. For the tach hook up, you can tap into one of the connectors underneath the glove box. Cannot recall the wire color. Makes it easy as i assume you will be locating your ecu in the passanger footwell where the stock one was. I had to use an inline resistor for the tach to function properly with a GM ecu. Not sure if that is required with the megasquirt.
Personally, I choose to bypass the porsche dme relay system and fuse box all together, and instead used a seperate relay/fuse block for the ecm, fuel pump etc. Only used the 14 pin for the guages.
Leva- Posts : 82
CyCloNe! likes this post
Re: ECU Wiring
There is a 4 pin flat connector close to where the Porsche ecu was located. The green/black wire in that connector is for the tach.
Re: ECU Wiring
CyCloNe! wrote:Once again you save the day, lol. Thank you!
Re: ECU Wiring
Just in case Pin #4 Didn't work for me to activate the fuel pump (Green/Black wire), I ended up using Pin #5 (Black/Grey). Seems to have worked, also I am using the factory DME relay. Just in case someone sees this post later. Everything else was correct.
Re: ECU Wiring
The green/black wire is tach signal to your tach. It would never work to activate the fuel pump.
Re: ECU Wiring
Hotrodz of Dallas wrote:The green/black wire is tach signal to your tach. It would never work to activate the fuel pump.
In the 14 Pin Harness Connector at the firewall? Pin #4 is tach there as well?
I am using the Tach in the 4 Pin connector you mentioned in footwell with the Green/Black, that's working fine.
Re: ECU Wiring
The 4 pin connector is what I was referring too. I use the ecu to trigger the fuel pump, not the 944 wiring.
Yesterday at 6:51 am by tonyorlo
» LS 928 5speed project here
» 951 Transaxles For Sale
» Turbo Transaxle wanted
