Brake Master Cylinder
I have a still-running 944 Turbo and would like to keep it that way up until the last possible second before LS swapping. I am considering prepping the car by converting to manual brakes now. I would like to end up with a floor-mounted pedal box, but would likely just use the Tilton dual master in the short term.
My question is, if I were to put the Tilton dual master in the current car, would I need to remove it again during the LS swap? If so, I won't bother at this point--would prefer to spend as little time dealing with brake fluid as possible.
Thanks!
Thanks!
z1 zonly- Posts : 8
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
