NA and 86 Turbo Billet Hubs
I guess this is the best place to post this. I am doing a small run of ONLY 4 sets of billet hubs for the NA and 86T cars that bolt the rotor over the hub just like the 87-up hubs/cars do. Any Big Brake kit will now fit the Early NA cars. They are about 5-6 times as strong as the factory cast hubs and will come with brand new bearings and seals installed. You'll need to press in your old studs or get longer ones if you choose. I'm doing a relief cut to lighten then another 200 grams, so they'll be close to stock weight as well......$575 shipped/pr anywhere in the US-48..... Just PM
Re: NA and 86 Turbo Billet Hubs
All the machining is done and these hubs will come with brand new bearings and grease seals pre-installed. Same price $575/set shipped US-48.....
Factory 86 Turbo spindle and caliper with the 87-Turbo front mounted rotor installed.....
I have 1 last set of these left. Just waiting on new bearings and seals to arrive. Im not sure I'll build any more of these this year. A few of the hybriders have these but I have not seen install pics. If you have them post em up. Any Big Brake kit/adapters I've done bolt right up to the early spindles when these are used.
What sort of weight do I reduce by putting these on my car? I presume you are out and I would have to wait until next year, correct?
BTW - you are phenomenal!
Ohh gosh, I just re-read the text and now see the weight note :-) Sorry, too excited geeking out to car stuff as of late
Jon, I sent out your Audi calipers and NA adapters with centering rings. Those will also work with these billet hubs and early NA spindles/suspension. If you want to wait another week, I have a spare set that I still need to router out the outer profile as the bearing lands have already been turned on CNC.
Do you still make these hubs?
Patb- Posts : 46
Patb wrote:Do you still make these hubs?
If Rob has none...I'll sell you the pair I bought at the same price from him several months ago.
New in box. (I went in another direction.)
-Tom
944convert- Posts : 253
Better snatch those up. I made a 2nd run and they are all gone. I don't plan on making any more unless someone wants to buy me a good used mazak turn station.
I can testify that everything xcshop creates is nothing less then the best!
I agree, his machine skills are top notch. I'm trying to get late hubs on a 86 spindle, I think I'm gonna research a little more before I get the hubs
Patb- Posts : 46
» billet hubs?
» Garage cleaning, 87+ porsche parts, turbo/nonturbo, 996 turbo twists
» WTB: 87+ wheel hubs
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
