__Z__'s 5.3 944
__Z__'s 5.3 944
I would like to mention I cannot take all credit for this build. My best friend since I was 2 recently purchased his parents house, and offered me his garage to build the car as he wants to learn more about building himself. So him and I have been working on it all together. Always nice to have a helping hand.
Car purchased
We decided on a 5.3 (after kicking around other ideas), initially I wasnt going to go FI, but with header costs for our build being over a grand, and knowing eventually we would want more power, just said screw it might as well.
Did some trading and got a 05 5.3 with under 100k on it (supposedly). It came with everything minus a harness. Some of it had already been disassembled.
Started ripping her down some more for block cleaning and painting.
Sprayed
While I really like the smooth valve covers, with my past experience of imcompletion, I decided to reuse the oem valve covers, and just keep the oem coil bracket locations. I am going to however have a set of bungs welded on for breathers
Ive already ordered a LS6 cam, as well as a dbc throttle body.
Plan to order the remainder list of parts needed in the next few weeks.
LS6 Lifters
Comp 918 Valve Springs
LS9 MLS Head Gaskets
LS2 Timing Chain Set
LS2 Oil Pump
ARP Head Bolt Set
Rod Bolt Set (Still unsure on a brand)
Moroso 20140 Oil Pan
7.425 Push Rods
I also picked these up simply because they were at a price I couldnt pass up.
Car purchased
Sprayed
LS6 Lifters
LS2 Oil Pump
ARP Head Bolt Set
7.425 Push Rods
__Z__- Posts : 10
Re: __Z__'s 5.3 944
Ive also started working on some of the stock parts to clean them up.
Smoothing the truck intake
Also, my fuel rail kit is on route. I text the guy, his name is Wayne, super nice guy.
He also asked what intake I would be using it with, he has custom intake brackets, even for truck intakes, hooked me up with polished rails, black fittings, black/red fuel crossover line, and a integrated fuel pressure gauges.
Link for anyone else interested. It has his cell number in there.
__Z__- Posts : 10
Re: __Z__'s 5.3 944
I also picked this up for a steal from a local when he was having a firesale.
__Z__- Posts : 10
Sat May 18, 2024 6:51 am by tonyorlo
» LS 928 5speed project here
» 951 Transaxles For Sale
» Turbo Transaxle wanted
