» ECU Wiring
'83 944 V8 LT-1 swap - Page 3 EmptyTue Jun 15, 2021 9:47 am by Hotrodz of Dallas
» bellhousing pressure plate interference
'83 944 V8 LT-1 swap - Page 3 EmptyMon Jun 14, 2021 9:07 pm by rjarvis
» LS Overheating Issue
'83 944 V8 LT-1 swap - Page 3 EmptyMon Jun 14, 2021 8:54 pm by rjarvis
» wtb: 16" early offset wheels
'83 944 V8 LT-1 swap - Page 3 EmptySun Jun 13, 2021 1:17 am by sharkey
» WTB 951 or S2 Trans
'83 944 V8 LT-1 swap - Page 3 EmptyFri Jun 11, 2021 4:13 pm by Rikstone
'83 944 V8 LT-1 swap - Page 3 EmptyWed Jun 09, 2021 3:00 am by spence
» TPC Throttle Cable Questions
'83 944 V8 LT-1 swap - Page 3 EmptyFri Jun 04, 2021 12:54 pm by CyCloNe!
» 944 LT1 engine mounts and dash lights
'83 944 V8 LT-1 swap - Page 3 EmptyFri Jun 04, 2021 8:47 am by quarterflash
» Modified Hooker 2312 Headers for sale
'83 944 V8 LT-1 swap - Page 3 EmptyFri Jun 04, 2021 7:29 am by gwistrup
'83 944 V8 LT-1 swap - Page 3 EmptyThu Jun 03, 2021 9:50 pm by Raymond-P
June 2021
78910111213
14151617181920
21222324252627
282930
Page 3 of 3 Previous  1, 2, 3
'83 944 V8 LT-1 swap - Page 3 Empty Re: '83 944 V8 LT-1 swap
Post  Admin Sat May 21, 2011 12:50 pm
It depends on the heads you have. It you motor/heads came with it then keep it,don't get rid of it just because someone told you they didn't use it on theirs!
Post  laptop_geek Sat May 21, 2011 1:13 pm
Admin wrote:It depends on the heads you have. It you motor/heads came with it then keep it,don't get rid of it just because someone told you they didn't use it on theirs!
Thanks, Did you run yours up to the radiator or TB?
laptop_geek
laptop_geek
Post  Admin Sat May 21, 2011 1:32 pm
I usually by pass the TB, unless it is a emissions car. Those are steam vents and they need to be run to the expansion tank .
Post  laptop_geek Sat May 21, 2011 1:36 pm
Cool. looking up the GM Part number (10108635) it looks like GM isn't selling them anymore. I'm gonna try and build my own outta rubber hose and fittings, then run that to the tank. Seem like it'll work with the rubber hose?
laptop_geek
laptop_geek
Post  laptop_geek Sat May 28, 2011 1:49 pm
Talked to some guys at my FLAPS. They suggested using rubber heater hose as well. Guess I'm headed to Lowes for some parts. If they have what I need I'll post the part numbers.
What do you guys do to hook up the throttle cable? Use the one from a Camaro or something else?
Has anyone used the alternator from the Camaro? The one I've got is 140 Amps and tested out to be good so I'd like to use it if possible.
laptop_geek
laptop_geek
'83 944 V8 LT-1 swap - Page 3 Empty I'm Back, and in need of help
Post  laptop_geek Tue Mar 06, 2012 5:43 pm
Well, after a little break and playing around with a couple of bikes, I have gotten seriously started back on this project.
I do have a favor to ask though, can anyone post a picture of the stock fuse box for a 1983 944? I (stupidly) took off the wires to the box thinking I needed them off to get the wiring harness out. I thought I took a picture of them before I took them off, but now can't seem to find it. If someone has a picture of what wires go to what fuses and relays that would be most helpful.
laptop_geek
laptop_geek
Post  RobotMachines Fri Mar 09, 2012 11:51 pm
Going to do my best with my crappy old digital camera. Be back in a few...
RobotMachines
RobotMachines
Post  RobotMachines Sat Mar 10, 2012 12:33 am
Here you go:
The white connector is closest to the driver's side door.
The yellow connector is towards the passenger side.
Let me know if I can be of more help Very Happy
RobotMachines
RobotMachines
Post  laptop_geek Sun Mar 11, 2012 2:12 pm
RobotMachines wrote:Here you go:
Thats awesome! Do you know how the G and H connections go? They are the wires directly behind the ones pictured.
laptop_geek
laptop_geek
Post  RobotMachines Sun Mar 11, 2012 6:23 pm
I can certainly try and find out. I'm not really sure which connectors/wires you are referring to though. Can you explain a little more? (G, H ?)
I'm working on the car now; changing the oil/filter which isn't fun with my remote filter setup. I may cut and weld a door in the stainless underbelly pan tonight so I don't have to take the entire stupid thing off again next time I change the oil... getting old (me and the having to remove the pan).
I REALLY want a car lift. I should have bought one 8 years ago and I'll probably say the same thing 8 years from now.
RobotMachines
RobotMachines
Post  laptop_geek Sun Mar 11, 2012 11:41 pm
The connections are behind (above actually, if the fuse block is in place) the pictured connections. They are all seperate, one wire terminals (not sure why Porsche did this as they have all the others nicely placed in the bundle). I did find out some information from the FSM, but I have a few wires that are still out of place (three or four). I did find out that all the wire that go to the "H" connection are red wires and feed the accessory fuse block; I believe they are hot all the time, might be a good place to pull power if needed. I think I have all of these in place as they should be. The other place, the "G" connections, I'm not so sure about. I followed the FSM wiring diagram, but still have extra wires.
laptop_geek
laptop_geek
