» FS: 1987 951 LS
New guy new build EmptyToday at 5:31 am by carr911
» Power Steering Issues
New guy new build EmptyYesterday at 1:54 pm by spence
New guy new build EmptyWed Sep 23, 2020 7:59 pm by chrenan
» WTB C5 2 piece bell housing
New guy new build EmptyWed Sep 23, 2020 1:10 pm by alex456gt
» backwards LS6 intake
New guy new build EmptyTue Sep 22, 2020 6:24 pm by murrayg
» Testing the waters. I have a working '83 944 with a '94 LT1 that I want to let go.
New guy new build EmptyMon Sep 21, 2020 7:44 am by Bmillar
» Totalled 1985.5 Porsche 944
New guy new build EmptyFri Sep 18, 2020 3:53 pm by Bmillar
» Clutch wont disengage!
New guy new build EmptySun Sep 13, 2020 10:51 pm by RobotMachines
» tachometer
New guy new build EmptyFri Sep 11, 2020 10:21 am by smkn951
» 86 Porsche 944T LS1 swap begins
New guy new build EmptyThu Sep 10, 2020 9:31 pm by smkn951
September 2020
78910111213
14151617181920
21222324252627
282930
New guy new build
New guy new build Empty New guy new build
Post  lvkid76 on Sun Oct 17, 2010 9:10 pm
Hello all.
I have been reading the forums and never posted. I have an 86 N/a 944. Owned for 3 years. Daily driver.
Just bought an 2000 LS1 with 20,000 miles from Ebay. I also just received a kit from Renegade Hybrids here in Las vegas. I also just ordered headers from texas performance concepts.
Hopefully to start on this build in the next couple weeks. I know I will have questions. lol
Nothing is as easy as it seams. just saying hello and hope to join the community.
Very Happy Very Happy Very Happy
lvkid76
New guy new build Empty Re: New guy new build
Post  944-LT1 on Sun Oct 17, 2010 9:22 pm
Welcome! Very Happy
Post  skywalker01 on Mon Oct 18, 2010 5:19 am
You've come to the right place!! Lots of people with diverse background and insight into the conversion process. No question is too dumb - believe me, I've asked a few!!
skywalker01
skywalker01
Post  Porch on Mon Oct 18, 2010 9:36 am
Welcome!
Post  xschop on Mon Oct 18, 2010 11:09 am
Only dumb question is the one not asked. Knowledge is power. Welcome
Post  944-LT1 on Mon Oct 18, 2010 12:59 pm
Well... the only dumb questions are the ones not SEARCHED for first! Laughing
Post  Arthropraxis on Mon Oct 18, 2010 7:06 pm
Is it just me or is the search engine on this site not very good?
Post  cfgioja on Mon Oct 18, 2010 7:13 pm
it like that on alot of these forum sites. They use google to search the web or site depending on the settings you choose.
Post  944-LT1 on Mon Oct 18, 2010 8:33 pm
You have to hit the search on the bar next to FAQ and then click adavanced search.
New guy new build Empty UPDATE
Post  lvkid76 on Tue Apr 26, 2011 1:46 pm
Little update to our progress. Been awhile since I posted. We finally got the motor in after painting the engine bay. Next will be running fuel lines, A/C lines, got Lokar throttle cable, wiring harness, and put the radiator back in.
Bought the CSR thermostat but didnt fit the stock thermostat. Had to do some forum searching and found it takes a small block chevy thermostat. I need to pick one up.
Other than that coming along. Got my Turbo front end along with turbo rear brakes. Still need the front brakes and larger wheels. but coming along. Hopefully 2 more weeks or so. Trying to make as clean as possible.
Last edited by lvkid76 on Wed Apr 27, 2011 10:18 pm; edited 1 time in total (Reason for editing : trying to get pictures to hold)
lvkid76
Post  acorad on Thu Apr 28, 2011 3:57 pm
Looks great!
Post  Admin on Thu Apr 28, 2011 4:16 pm
What radiator and fan setup are you going to use?
Post  acorad on Thu Apr 28, 2011 4:30 pm
Admin wrote:What radiator and fan setup are you going to use?
And how are you going to mount the rad?
I've just had my RH/Ron Davis rad repaired as it sprang some leaks. Both RH and Ron Davis say the rads have to be mounted just right, so that they don't get damaged when the car flexes.
New guy new build Empty radiator
Post  lvkid76 on Thu Apr 28, 2011 9:46 pm
I purchased the renegade radiator set up and also the wiring kit that included the reflash.
The radiator looks really nice. should go in quick. neMed to buy a new condenser. want all new in the car. just bought new radiator coolant tank and brake reservoir tank. new plastic looks much better.
My father and I are only worried about the wiring part. the Harness is nice but does not explain what to do with it. Been reading about which wires go where. I will post of course if we cant figure it out.
lvkid76
Post  Admin on Fri Apr 29, 2011 7:12 am
If you purchased it from RH, call them. they should explain the wires to you. That's part of the customer service,
New guy new build Empty upate to project
Post  lvkid76 on Sun Nov 04, 2012 7:33 pm
Been awhile. After switching jobs and moving out of Nevada to Utah. Finally started working on project again. Upate
Got exhaust done. installed fuel lines, Oil Lines, Radiator, brakes, clutch. I have the wire harness in and just need to mount ECU and connect the 10 or so wires, need a battery and battery cables. Everything is looking good so far. Have all parts for Turbo front end and got all my parts for big brakes. Hopefully soon now. Should be able to fire up soon.
a Couple pics.
lvkid76
Post  Porch on Sun Nov 04, 2012 9:09 pm
Looks like a clean install! Almost there... Cool
