Disconnecting the engine wiring harness
Where do you find the area where the porsche harness can be disconnected?
kelleysj- Posts : 194
Re: Disconnecting the engine wiring harness
take the carpet up from under the passenger footwell, unplug the DME from the harness and the rubber harness boot on the passenger firewall snaps out, then pull the harness from the engine bay side
Sweet thanks man
Make sure you save the rubber insulator that protects it from the firewall.
» A couple engine wiring harness questions
» wiring harness connected to 944 harness?
» Wiring Harness
» Wiring Harness
