» Kooks headers on eBay
Xschop's 5.3 LM7 build - Page 8 EmptyYesterday at 8:54 pm by Admin
» 85 5.3 swap
Xschop's 5.3 LM7 build - Page 8 EmptyTue Oct 20, 2020 4:15 pm by smkn951
» low cost and available bellhousing...maybe
Xschop's 5.3 LM7 build - Page 8 EmptyTue Oct 20, 2020 2:16 pm by Admin
» Starter issues
Xschop's 5.3 LM7 build - Page 8 EmptySun Oct 18, 2020 12:48 pm by zeusrotty
» Sharkey's 944 corvette t56 swap thread
Xschop's 5.3 LM7 build - Page 8 EmptyTue Oct 13, 2020 10:01 am by Myporschels
» FS: 1987 951 LS
Xschop's 5.3 LM7 build - Page 8 EmptyTue Oct 13, 2020 5:41 am by carr911
» 5th gear options, Audi?
Xschop's 5.3 LM7 build - Page 8 EmptyMon Oct 12, 2020 1:18 pm by acorad
» Garage queens
Xschop's 5.3 LM7 build - Page 8 EmptyMon Oct 12, 2020 11:57 am by gdopnt
» Where did you find your LS1? I need one :)
Xschop's 5.3 LM7 build - Page 8 EmptySun Oct 11, 2020 10:33 pm by smkn951
» 78 928 LS1 swap initiated
Xschop's 5.3 LM7 build - Page 8 EmptyThu Oct 08, 2020 12:21 pm by Hey_Allen
October 2020
Page 8 of 17 Previous  1 ... 5 ... 7, 8, 9 ... 12 ... 17  Next
Xschop's 5.3 LM7 build - Page 8 Empty X-member Mod Pictorial
Post  xschop on Sun Feb 27, 2011 1:27 pm
When I did my swap I didn't get good pics of the X-member mod. I Did the first step to modding an X-member for the Moroso 20140 oil pan on the passenger's side steering rack mount. It important that you trim the mount boss at an angle upwards to give it support strength
...... Next step line-boring for 1" X-member drop at the control arms....
Xschop's 5.3 LM7 build - Page 8 Empty Heat shielding wires
Post  xschop on Sat Mar 12, 2011 6:41 pm
Well #3 plug wire started fouling. I peeled back the aluminum foil wrap and the silicon sheath has heat cycled and has cracks. I have a temporary 8mm blue wire made up and want to find the best heat resistant plug wires/wrap for the truck coils. What's the best set-up?
BTW, the truck coils will arc on the valve covers from an inch away....when the plug wire is removed....amazing.
Xschop's 5.3 LM7 build - Page 8 Empty C5 water pump spacers
Post  map21 on Sat Mar 12, 2011 9:25 pm
XSCHOP are you still making the C5 water pump spacers, Alternator and PS pump bracket that you created for your 5.3 truck install. Also which LS1 intake did you use
(i.e Corvette/ Trans-am / Camaro) or are they all the same.
I am having a 5.3 944 build done and am in the final stages of parts ordering and your set up seems to be the best way to avoid switching to all LS1 accessories.
map21
map21
Xschop's 5.3 LM7 build - Page 8 Empty Re: Xschop's 5.3 LM7 build
Post  xschop on Sun Mar 13, 2011 1:55 am
I can make the setup. You need to order that March Performance pulley and send it to me. I'll build the rest and ship it for $200. PM me or email [You must be registered and logged in to see this link.]
Post  map21 on Sun Mar 13, 2011 3:00 am
Awesome, do you have a part number on that March pulley. I see they have quite a few on their site.
map21
map21
Post  xschop on Sun Mar 13, 2011 3:24 am
Are you running the truck crank pulley?
Make sure you read everything here.... The adapter bracket can us the Truck or F-body Crank pulley. I'm still running the truck pulley and can remove my fans from the front of the radiator even, no need to stick on f-body crank pulley at all, keep it all truck.
Post  map21 on Sun Mar 13, 2011 3:25 am
Currently yes. I was not aware of a need to swap it.
map21
map21
Post  xschop on Sun Mar 13, 2011 3:31 am
March Performance pulley #6271..... I'll do the rest.... Are you also going power steering?
Also I removed my idler bracket, it was unnecesary because the Billet March pully is such a large dia, with plenty of belt grab.....quiet too.
You should be able to PM now with 5 posts....
Post  map21 on Sun Mar 13, 2011 3:37 am
I really cant remember if the car has PS or not. Its an 83 na but I'm gonna say yes because I may run hydraboost for the brakes and then I would need it & this will make my 5th post so I should be able to PM now.
map21
map21
Post  xschop on Sun Mar 13, 2011 3:40 am
PM sent....
IF you go 18's you'll also want PS IMO.....
Running the NA radiator? NA radiator has zero problems, Getting warmer outside so I removed the 180 T-stat & just reinstalled a new 160 degree T-stat for the summer....cool as can be with the 5.3
EDIT.... also member Tehone found that the new 2010 Camaro Water Pump does NOT need the WP spacers when using the Truck crank pulley Very Happy
Post  xschop on Mon Mar 14, 2011 11:54 am
Looks like we'll have another 948 owner this summer. After a test ride in mine, the shop owner got on the phone and bought a Silver 944 from some lady that threw a belt and towed it to his shop. Of all his P-cars I was more impressed that he's doing a ground up rebuild of this.....Wonder if I could talk him into a GM V8 swap lol...
Post  robstah on Mon Mar 14, 2011 5:32 pm
I see you are doing a great job on the recruiting front. Razz
Did you ever drop a cam in there, Rob?
Post  xschop on Tue Mar 15, 2011 8:02 pm
Not yet, I have the LS6 cam and the guys on performance trucks say it gives another 40HP, but they are up in the air on gas mileage and low end torque. I am happy with my gas mileage and power for now. Working on a Turbo LSD t-axle soon, then I'll want more HP. I smacked a Pontiac G8 around a couple days
ago.
Post  modenas on Wed Mar 16, 2011 3:54 pm
i like what your doing, but if u want more power i got a set of vette heads that have been ported and polished
modenas
modenas
Post  xschop on Wed Mar 16, 2011 4:29 pm
I have new rebuilt Z06 heads with springs for my next upgrade after the cam swap. Looks like I'm going to have to get a proper clutch disc designed now before I'm sticking in any more juice.
Post  v8carreragts on Wed Mar 16, 2011 5:04 pm
Doesn't anyone make a double disc clutch for the LS? In theory the second disc should double the holding power---same clamping force but double the surface area.
Post  cfgioja on Wed Mar 16, 2011 5:59 pm
If I am not mistaken doesnt spec make one?
Post  robstah on Wed Mar 16, 2011 8:48 pm
v8carreragts wrote:Doesn't anyone make a double disc clutch for the LS? In theory the second disc should double the holding power---same clamping force but double the surface area.
The maximum torque load that can be held by a disc is a function of the overall disk size (the disc contact start/stop radius more specifically, as we can normalize it to about the center of that point) and the clamping load. Surface area has nothing to do with the holding power, only heat shed ability. Coefficient of friction is dimensionless.
Post  xschop on Wed Mar 16, 2011 10:03 pm
CP-4018
O.D.= 11"
I.D. = 6.5"
2.25" across the friction material
Post  docwyte on Thu Mar 17, 2011 8:48 am
The Spec clutches hold a ridiculous amount of torque, much more than any LS motor can make unless you turbo charge one.
My stage 2 disch supposedly is goo for 550 ft lbs or something like that. The stage 2 hybrid, which they wanted to sell me, was good for over 700 ft lbs. They didn't quite seem to understand that I didn't need something like that...
Post  xschop on Thu Mar 17, 2011 9:21 am
Hey Doc, I chose the specific Dodge disc because of IT"S SPLINE ENGAGEMENT LENGTH was the longest out of the 4 different ones I looked at. ANY system is only as strong as it's weakest link....
Post  docwyte on Thu Mar 17, 2011 9:23 am
I'm more of a fan of buying something that's designed to fit, rather than getting something for another application then trying to make it fit.
You have the luxury of having the skills and tools to make things work that the rest of us don't...
Post  xschop on Thu Mar 17, 2011 9:28 am
Actually, I would have another shop do the inner spline hobbing for a one-off and make it the Porsche pattern at 1.5" length. Eventually someone's going to actually measure the Spec clutch spline length and post it.
Post  Arthropraxis on Thu Mar 17, 2011 11:00 am
Is it possible/practical to get a new drive shaft made with the Corvette spline?
Post  cfgioja on Thu Mar 17, 2011 11:08 am
I have the stage 2 kevlar spec clutch,according to their tech they will all have the same spline length. I will get mine measured tonight and post what I get.
