Mon Jul 08, 2013 1:56 pm by Admin
» Wanted to buy swap parts
Xschop's 5.3 LM7 build - Page 5 EmptyToday at 6:48 am by nphd2000
» WTB 951 LSD Transaxle
Xschop's 5.3 LM7 build - Page 5 EmptyYesterday at 7:27 am by Sirayden
Xschop's 5.3 LM7 build - Page 5 EmptyThu Sep 16, 2021 9:03 am by Rich L.
» 944 Early Sun Visors vs Newer
Xschop's 5.3 LM7 build - Page 5 EmptyWed Sep 15, 2021 2:11 pm by Hotrodz of Dallas
» Confused about brakes
Xschop's 5.3 LM7 build - Page 5 EmptyMon Sep 13, 2021 8:52 am by Bmillar
» 944 ls track car
Xschop's 5.3 LM7 build - Page 5 EmptySat Sep 11, 2021 5:11 pm by Leva
» LS Overheating Issue
Xschop's 5.3 LM7 build - Page 5 EmptySat Sep 11, 2021 7:13 am by Hotrodz of Dallas
» 944 LS Conversion Parts near Charlotte, NC
Xschop's 5.3 LM7 build - Page 5 EmptyThu Sep 09, 2021 10:44 am by rrracing1970
» Sharkey's 944 corvette t56 swap thread
Xschop's 5.3 LM7 build - Page 5 EmptyWed Sep 08, 2021 10:48 pm by Raymond-P
» Full exhaust for rover V8 inc headers
Xschop's 5.3 LM7 build - Page 5 EmptyTue Sep 07, 2021 6:19 am by Hotrodz of Dallas
September 2021
6789101112
13141516171819
20212223242526
27282930
+46
piperporsche180944
jwink25
beario
shokwave30
Powerman951
Constantine
skywalker01
stu wright
suboptimalfit
odurandina
mvallee
Bluemach1
CyCloNe!
Marky522
LEEEZARD7
Tehone
airheadhubs
HHPtoy
map21
cjbcpa
Luke714
adam7e
Wild Bill
modenas
kelleysj
968gene
ffmedic
Tetzuoe
50 posters
Page 5 of 17 Previous  1, 2, 3, 4, 5, 6 ... 11 ... 17  Next
Xschop's 5.3 LM7 build - Page 5 Empty Bolt-on hood pin made easy
Post  xschop Wed Jul 21, 2010 11:51 pm
You will need about 1/4 inch thick of washers between long bracket and the 944 headlight swingarm pivot. I used Spectre brand part# 42563 and the carbon fiber hood protectors from a cheapy Chinese made Ebay hood pin kit.... The smaller bracket bolts to the long bracket end and swivels for a perfect contour match of your hood.....
The 1/2" hole diameter can be changed to suit any dia. hood pin......
I unbolted only the 2 top M6 x 1.0 bolts and installed longer ones..... No need to readjust the swingarm mechanism with a 2-bolt design and it is plenty strong..... (thanks for the reference pic Luke)
Xschop's 5.3 LM7 build - Page 5 Empty Re: Xschop's 5.3 LM7 build
Post  Luke714 Thu Jul 22, 2010 4:20 am
haha, no problem. Looks good. The post cut off your diagram and I can't follow a link to see it full size anywhere.
Luke714
Luke714
Post  xschop Thu Jul 22, 2010 6:23 am
Right click with your mouse and choose "view image"....
Post  Porch Thu Jul 22, 2010 7:16 am
Good idea for hood pin placement! I have seen some ugly and downright dangerous hoodpin placements on rennlist, but i think you've really got something there!
Post  xschop Thu Jul 22, 2010 10:35 am
It passes the xschop design module....you can beat on it with a hammer and she stays put, LOL
If you can't do this mod in less than an hour.5 then you have issues Razz
Post  modenas Thu Jul 22, 2010 4:17 pm
o she sounded sweet!! cant wait for a vid of her!!
modenas
modenas
Post  Luke714 Thu Jul 22, 2010 4:32 pm
What sort of hood pin kit did you order. Obviously you ditched everything below the hood, but I know nothing about installing a set.
Luke714
Luke714
Post  xschop Thu Jul 22, 2010 4:32 pm
Can't wait till Monday when I set off all the alarms in the parking garage Twisted Evil
Spectre part# 42563.... IT is easy to install with the posted dims. My camera went to $hit, so no pics yet.
Autozone has them for 9.99 plus tax...You do not need a mill to make the brakets, I used 90 Degree brackets from Ace hardware (.69 ea) and some 1/4" alum. bar I had laying around....
The whole set-up is adjustable and I just epoxied the carbon fiber hood protector on and didn't even screw in the 4 sheet metal screws....old skool meets new....
Post  xschop Thu Jul 22, 2010 6:15 pm
Friggin relay G2 (fuse box states ign. relay) runs the factory gauges and the warning light stays on after I turn the key off and pull it out. If I hit the horn button or turnsignal switch, the gauges turn off and the warning light goes out?
I removed G14 (another ign. relay) and the Warning buzzer/catalytic converter warning relay as well....
Anybody else have this situation?
She starts and runs perfectly, I just hate the fact that it seems the relay needs to be called to ground after the key is pulled.....
OH yeah, the 5.3 pulls like a mule on roids Twisted Evil
It's hard to keep my foot out of it, the neck snap is addictive.... Razz
Xschop's 5.3 LM7 build - Page 5 Empty Got a runner
Post  xschop Sun Jul 25, 2010 12:24 pm
I have my 2.5" Magnaflow (18" length) installed now with no CAT and love the sound....It's not thumpy like the Flowmaster mufflers and gives strong pull at higher RPM's. I didn't realize it was straight thru until I pulled it out the box at the exhaust shop.
Thanks again to Eric for a tip..... as I took the beast to Autozone and had them flash the PCM....it read "open Fuel injector circuit"...so took it home pulled all the injectors and took a 9-volt battery w/leads and some acetone/gas mixture in a syringe and actuated the injectors while applying pressure from the syringe to the injector inflow...Sure 'nuff one was totally clogged and the acetone mix cleaned it right out. The others were dirty but not clogged. I reinstalled and took it for a spin.....I love this engine. I drove almost 150 miles this weekend and looks like I'm almost getting 30 mpg. I will do a full tank experiment as I daily drive it and report back.
But the real fun is 3rd and 4th gear roll-ons on the hiway......Like my Streetfigher, only with 4 wheels.
I 'm glad I decided to keep power steering as the 18"s would be a bitch with my small diameter steering wheel. I do however have the infamous "click" in the rack pinion and will be getting a rebuilt one if I can't find a good used one.
The short shifter mod....love that too as it is needed from 1st to 2nd. I have gotten onto it but no clutch dropping going on until I have my transaxle built. IMO the NA tranny can handle the 315 horses without worrying...
Onto the cooling system,....The NA radiator (with no thermostat) has handled the 100+ temps these last few days in stop and go traffic. My digital gauges finally read 190 after running it hard and the low fan finally kicked on. I have yet to see the 2nd fan kick on so I'm not sure what temp SSP programmed that at....I will report anything else I find later.....Off to "get some groceries" Very Happy
Xschop's 5.3 LM7 build - Page 5 Empty Found it
Post  xschop Wed Jul 28, 2010 9:51 am
My wiring is complete. I found that pesky 4-pin connector that's in the electrics schematic. When I got the car the DME was already pulled and the red plastic 4-pin connector was hanging in the passenger footwell all the time.....
Post  xschop Mon Aug 02, 2010 9:52 am
At 60mph hiway cruising in 5th gear (NA tranny) I am spinning 2300 RPM. Does this sound correct to you guys?
Almost forgot to mention that I jumped the 2 wire leads that were originally connected to the brake fluid reservoir and jumped the brake pad sensor leads....No More warning light Very Happy
Xschop's 5.3 LM7 build - Page 5 Empty Getting my mill on...and my lathe on
Post  xschop Tue Aug 10, 2010 9:02 am
The VSS sensor that is in the swap manual is $70 even at Rock Auto...
I redesigned the flimsy metal VSS bracket to use the INEXPENSIVE $19 Autozone part # SU-1089 which crosses with GM part #24225896
The slotted 3/8" diameter transaxle bolt holes gives it plenty of adjustability with a turn of the allen wrench and the sensor comes with a 1/4" bolt down hole that makes installation a snap and has a debris protection shield built in too....
With the bracket design, you can cut half the diameter of the CAM reluctor gears off for rotational weight reduction as well.....
Post  modenas Tue Aug 10, 2010 9:09 am
are you making one of these for me 2?
modenas
modenas
Post  xschop Tue Aug 10, 2010 9:25 am
No, just a 1-off billet bracket on this one.
You can weld together 1/4" plate and get the same outcome. Just posting for the DIY crowd, save $50 over the other sensor and buy some beer.... drunken
Post  modenas Tue Aug 10, 2010 11:48 am
ok btw did anyone buy ur other alt bracket and powering steering pulley? i love mine that i have
modenas
modenas
Post  xschop Wed Aug 11, 2010 8:03 am
I sold one and have another left, but haven't bought another March Pulley to mod for it. You need a spare?
My VSS kit is done, I made the bracket even lighter/compact and by just doing a 5/8"x4x4 thick billet plate. I test fitted the plate and it fits perfect.
I spent more time on the 944 Cam gear to get rid of a whopping 400g of rotational weight..... the trick is to slice it in half radially.....
it now weighs only 330g.... Very Happy
Post  xschop Wed Aug 11, 2010 8:26 am
Can't wait to see what the MPG's do after I install it.....
Post  modenas Wed Aug 11, 2010 5:30 pm
what this? you can take pic of your parts but not one of the car?
modenas
modenas
Post  xschop Sat Aug 14, 2010 9:21 am
Thinking about paint scheme......
If it only had a V8......
Post  modenas Sat Aug 14, 2010 2:39 pm
hey hey, chop you know all 4 b****** got to be at *********.com now it be nice for a v8 but they to high and mighty for that
modenas
modenas
Post  Porch Sat Aug 14, 2010 10:48 pm
Oh man.
So the front end they pretty much just tried for a Camaro...
And the back end they just tried to make as ugly as possible.
It's a shame it's not a V8 car, that way they could have gotten it up to a pretty good speed before launching it off a cliff into the ocean to put it out of its misery!!
Post  xschop Sun Aug 15, 2010 5:35 pm
Installed my Billet VSS bracket/944 Cam Reluctor .......
The strange deceleration behavior is gone now and my low fan doesn't kick on when cruising the hi-way when the water temp reaches 180*..... Very Happy
And I walked all over a WRX with a couple of 2x4's and a bag of cement in the back coming home from Homie Depot Razz
Post  xschop Sun Aug 15, 2010 8:19 pm
I wanted to post this up before I forgot dims....
85.5 NA axles are @ 21.25" (I only measured passenger side and was told that the driver's side is the same length on the 944 trans boxes, correct me if I'm wrong)
Here's the kicker.....the 944 axle shafts are 27mm Diameter.....and I found that 930 axle shafts are 26mm Diameter and 18.9"
Post  xschop Fri Aug 27, 2010 7:58 pm
Laid waste to another victim today.....350z all show and no go......
I have ragged the piss out of the $40 Autozone clutch disc (CP4018) and NO slippage. It does sound a little scratchy upon take of when feathering the clutch. With the NA tranny, I can launch hard in 2nd gear with a little vibration, but have learned to feather it smoothly. I have lit the tires up in 2nd and third roll ons even. 4th is the most fun, nutty acceleration on the Hiway and 5th is getting me right at 30mpg's (100% petro/Acetone 640:1)
In the past couple of weeks I've put @400 miles on it...... Wish I had done one of these sooner....
Hood pin mod is awesome too....got rid of a few extra pounds and looks mean....
