» ECU Wiring
TPC Throttle Cable Questions EmptyTue Jun 15, 2021 9:47 am by Hotrodz of Dallas
» bellhousing pressure plate interference
TPC Throttle Cable Questions EmptyMon Jun 14, 2021 9:07 pm by rjarvis
» LS Overheating Issue
TPC Throttle Cable Questions EmptyMon Jun 14, 2021 8:54 pm by rjarvis
» wtb: 16" early offset wheels
TPC Throttle Cable Questions EmptySun Jun 13, 2021 1:17 am by sharkey
» WTB 951 or S2 Trans
TPC Throttle Cable Questions EmptyFri Jun 11, 2021 4:13 pm by Rikstone
TPC Throttle Cable Questions EmptyWed Jun 09, 2021 3:00 am by spence
» TPC Throttle Cable Questions
TPC Throttle Cable Questions EmptyFri Jun 04, 2021 12:54 pm by CyCloNe!
» 944 LT1 engine mounts and dash lights
TPC Throttle Cable Questions EmptyFri Jun 04, 2021 8:47 am by quarterflash
» Modified Hooker 2312 Headers for sale
TPC Throttle Cable Questions EmptyFri Jun 04, 2021 7:29 am by gwistrup
TPC Throttle Cable Questions EmptyThu Jun 03, 2021 9:50 pm by Raymond-P
June 2021
78910111213
14151617181920
21222324252627
282930
TPC Throttle Cable Questions Empty TPC Throttle Cable Questions
Post  CyCloNe! Fri Jun 04, 2021 8:08 am
Hey everyone got a few questions regarding the throttle cable I received from TCP.
1) The End to the Pedal Does it have to be changed out? As the Porsche was a female end that was like a rubber grommet. Do I cut off the nipple and drill the pedal?
*Note after further inspection I do notice one end that connects to the throttle cam has to be changed out but still curious about the cable attaching to the pedal.
I'll post a pic and a second but I see the kit came with cable stops so just want to make sure I do this the right way. Thank you!
CyCloNe!
TPC Throttle Cable Questions Empty Re: TPC Throttle Cable Questions
Post  CyCloNe! Fri Jun 04, 2021 8:16 am
https://i.servimg.com/u/f91/20/32/75/03/20210612.jpg
https://i.servimg.com/u/f91/20/32/75/03/20210613.jpg
CyCloNe!
Post  Hotrodz of Dallas Fri Jun 04, 2021 12:23 pm
You can drill out the pedal so the cable clevis pins to it. I have also drilled the holes in the clevis just big enough to go over the pedal pin and used a piece of rubber vacuum hose in the clevis to hold the cable on similar to the grommet that Porsche used.
The other end uses a barrel fitting that goes in the throttle body cam. The cable inserts into the barrel fitting and the set screw holds the cable in.
Hotrodz of Dallas
Hotrodz of Dallas
CyCloNe! likes this post
Post  CyCloNe! Fri Jun 04, 2021 12:54 pm
Thank you sir!
CyCloNe!
