» Wanted to buy swap parts
Switched light power for aux gauges EmptyToday at 8:48 am by nphd2000
» WTB 951 LSD Transaxle
Switched light power for aux gauges EmptyYesterday at 9:27 am by Sirayden
Switched light power for aux gauges EmptyThu Sep 16, 2021 11:03 am by Rich L.
» 944 Early Sun Visors vs Newer
Switched light power for aux gauges EmptyWed Sep 15, 2021 4:11 pm by Hotrodz of Dallas
» Confused about brakes
Switched light power for aux gauges EmptyMon Sep 13, 2021 10:52 am by Bmillar
» 944 ls track car
Switched light power for aux gauges EmptySat Sep 11, 2021 7:11 pm by Leva
» LS Overheating Issue
Switched light power for aux gauges EmptySat Sep 11, 2021 9:13 am by Hotrodz of Dallas
» 944 LS Conversion Parts near Charlotte, NC
Switched light power for aux gauges EmptyThu Sep 09, 2021 12:44 pm by rrracing1970
» Sharkey's 944 corvette t56 swap thread
Switched light power for aux gauges EmptyThu Sep 09, 2021 12:48 am by Raymond-P
» Full exhaust for rover V8 inc headers
Switched light power for aux gauges EmptyTue Sep 07, 2021 8:19 am by Hotrodz of Dallas
September 2021
6789101112
13141516171819
20212223242526
27282930
Switched light power for aux gauges Empty Switched light power for aux gauges
Post  knucklehead12 Sat Mar 20, 2021 6:32 pm
Where is the easiest place to pull power from to power auxiliary gauges? Want them to light up when headlights are switched on.
knucklehead12
Switched light power for aux gauges Empty Re: Switched light power for aux gauges
Post  Leva Sun Mar 21, 2021 12:35 am
Well, then you need to wire your gauge lighting thru the headlight switch circuit.
Leva
Post  Hiroller Thu May 20, 2021 11:46 pm
Since your instrument lights should come on when the headlights turn on, I would suggest taping one of the lights close to your gauges. Although the instrument lights usually use a small AWG wire, your additional lights shouldn't require much additional current unless your gauges have several light bulbs (incandescent not LED). If your gauges use LED lighting, you'll have negligible current draw added to your circuit. Your best test is to make a temporary connection and turn on the lights. Your gauge lights should come on, and your instrument lights should still be as bright as they usually are. If the instrument lights get dim, you'll know you added too much and will need to look for another connection.
Hiroller
Post  Hotrodz of Dallas Fri May 21, 2021 12:58 pm
On 86 and newer 944's, there's a light right behind the center ac vent. I've tapped into it on several different cars for gauge light power. Never had any issues with that.
Hotrodz of Dallas
Hotrodz of Dallas
