951 tach wire?? LS Swap
Hey guys I’m sure this has been asked many many times. I have an 86 951, what wire on the car am I supposed to tap into to make the factory tach to work?? And yes I’m doing and LS swap
C4924S- Posts : 53
Re: 951 tach wire?? LS Swap
This is from my notes on my 87. I am not sure if the 86 is the same or not, but this should at least give you a place to start.
I assume you have the 86 wiring diagrams? If not, they're available online. I can get the URL if you need it.
And good luck w/the project!
87944turbo- Posts : 76
