» wtb: 16" early offset wheels
WTB: Front sleeve kit and inserts EmptyToday at 1:17 am by sharkey
» WTB 951 or S2 Trans
WTB: Front sleeve kit and inserts EmptyFri Jun 11, 2021 4:13 pm by Rikstone
» LS Overheating Issue
WTB: Front sleeve kit and inserts EmptyThu Jun 10, 2021 11:24 pm by zeusrotty
WTB: Front sleeve kit and inserts EmptyWed Jun 09, 2021 3:00 am by spence
» ECU Wiring
WTB: Front sleeve kit and inserts EmptyFri Jun 04, 2021 12:56 pm by Hotrodz of Dallas
» TPC Throttle Cable Questions
WTB: Front sleeve kit and inserts EmptyFri Jun 04, 2021 12:54 pm by CyCloNe!
» 944 LT1 engine mounts and dash lights
WTB: Front sleeve kit and inserts EmptyFri Jun 04, 2021 8:47 am by quarterflash
» Modified Hooker 2312 Headers for sale
WTB: Front sleeve kit and inserts EmptyFri Jun 04, 2021 7:29 am by gwistrup
WTB: Front sleeve kit and inserts EmptyThu Jun 03, 2021 9:50 pm by Raymond-P
» lm7 944 swap in the uk
WTB: Front sleeve kit and inserts EmptyThu Jun 03, 2021 3:18 pm by mistert1996
June 2021
78910111213
14151617181920
21222324252627
282930
WTB: Front sleeve kit and inserts Empty WTB: Front sleeve kit and inserts
Post  matt889 Mon Jan 14, 2019 7:59 am
hi im looking for a Front sleeve kit for my 1986 944 NA with the Iron block Swap.
ISO:
Front sleeve kit with spring for Rebuildable strut ( Twist caps )
Koni Inserts for Rebuildable struts !
Currently have Stock struts with KYB inserts and SP-200 Lowering springs
Rear is to be installed Koni/huntley Rear coilovers with 500lbs springs or 300lbs springs
matt889
WTB: Front sleeve kit and inserts Empty Re: WTB: Front sleeve kit and inserts
Post  knucklehead12 Mon Jan 14, 2019 9:37 am
I have a set of 86 turbo non rebuildable struts complete with springs if you are interested. I just cut the set on mine and installed the koni struts in them. I Could cut these and drill if you want.
knucklehead12
Post  matt889 Mon Jan 14, 2019 9:49 am
knucklehead12 wrote:I have a set of 86 turbo non rebuildable struts complete with springs if you are interested. I just cut the set on mine and installed the koni struts in them. I Could cut these and drill if you want.
i am looking for the sleeve kit and springs , I have the 1986 struts already and didnt want to change from Early Offset to late offset with the different struts of the late model
matt889
Post  matt889 Tue Jan 15, 2019 7:55 am
BBB
matt889
