Tach wires??
Tach wires??
Hello im actually currently swapping 2 944’s at the moment, and im at the point in both builds where im trying to find the tach gauge wire to connect to it. I have the outputs at the PCM from the LS Ready just need to find where the wires go.
1st car is an 86 944 turbo
2nd car is an 84 944 NA
Thanks in advance!
Thanks in advance!
C4924S- Posts : 53
Re: Tach wires??
In case no one answers your questions....Using the search function up top, clicking on the advanced tab gives us these results. ==> [You must be registered and logged in to see this link.]
You will find the answers in these posts.
Re: Tach wires??
Do people not run a tach?
Sent from Topic'it App
C4924S- Posts : 53
Re: Tach wires??
The LS give a 4 cylinder signal. Been a while since I did the wiring, it was a one wire hookup, IIRC.
Re: Tach wires??
Yeah I read that. Just need to find the wire on the Car end to attach the wire to
C4924S- Posts : 53
Re: Tach wires??
Search result 17, from the link I provided earlier.
