I broke my car - Page 2 EmptyToday at 8:36 pm by Reason
» backwards LS6 intake
I broke my car - Page 2 EmptyToday at 6:24 pm by murrayg
» WTB C5 2 piece bell housing
I broke my car - Page 2 EmptyToday at 10:39 am by murrayg
» Testing the waters. I have a working '83 944 with a '94 LT1 that I want to let go.
I broke my car - Page 2 EmptyYesterday at 7:44 am by Bmillar
» FS: 1987 951 LS
I broke my car - Page 2 EmptyYesterday at 6:30 am by carr911
» Totalled 1985.5 Porsche 944
I broke my car - Page 2 EmptyFri Sep 18, 2020 3:53 pm by Bmillar
» Clutch wont disengage!
I broke my car - Page 2 EmptySun Sep 13, 2020 10:51 pm by RobotMachines
» tachometer
I broke my car - Page 2 EmptyFri Sep 11, 2020 10:21 am by smkn951
» 86 Porsche 944T LS1 swap begins
I broke my car - Page 2 EmptyThu Sep 10, 2020 9:31 pm by smkn951
» stalls when braking
I broke my car - Page 2 EmptyThu Sep 10, 2020 10:55 am by spence
September 2020
78910111213
14151617181920
21222324252627
282930
I broke my car
Page 2 of 3 Previous  1, 2, 3  Next
I broke my car - Page 2 Empty Re: I broke my car
Post  acorad on Wed May 04, 2011 3:49 pm
Thanks Spence, that's a good idea. It's kind of an awkward space, but maybe I could get a cold chisel on the bent-over side and try to bend it back a little to loosen it up.
I broke my car - Page 2 Empty stage8 bolts
Post  gamman on Sun May 08, 2011 1:15 am
I have a set of stage8's sitting in my garage, never used, still in the package.
make me an offer, I sold my car, but am always trolling to find another one. I never got around to road racing mine. Too chicken.
anyway, my paypal and email is my user name with a 3 at the end, at yahoo dot com
if you can't get it, pm me.
Last edited by gamman on Sun May 08, 2011 1:15 am; edited 1 time in total (Reason for editing : added never used)
gamman
gamman
Post  acorad on Mon May 09, 2011 11:35 am
gamman, thanks, I had already ordered some Stage 8's and they arrived today.
Post  Dawgz83948 on Mon May 09, 2011 11:37 am
acorad wrote:gamman, thanks, I had already ordered some Stage 8's and they arrived today.
Hey, I went to EASY this saturday and met your car's previous owner. He bought another 944 Turbo and an older 911.
Post  acorad on Mon May 09, 2011 11:40 am
Craig H? He's been great, always happy to help when I have questions. What's EASY?
And it looks like an early 80's 911 SC is going to joing our fleet pretty soon, too....
Post  Dawgz83948 on Mon May 09, 2011 11:49 am
EASY is an autodismantler in Emeryville, Ca. 1st and 3rd Saturday of the month a group of Porsche owners go and show their car there, as well as pickup any new/used parts they need. I got there every once in a while, but the 944 showing is very poor. Crying or Very sad Once your up and running and if you want to go let me know I'll go too.
My car is down right now for a week or so, I'm adjusting my rocker arms.
Post  acorad on Mon May 09, 2011 12:00 pm
Sounds like fun! We get up to Monterey 3-4 x year, we have relatives up there, maybe we can tie in a trip to the bay area one of these trips. Thanks!
Post  Dawgz83948 on Mon May 09, 2011 12:37 pm
acorad wrote:Sounds like fun! We get up to Monterey 3-4 x year, we have relatives up there, maybe we can tie in a trip to the bay area one of these trips. Thanks!
Let me know when you go, I like meeting fellow hybriders.
Post  acorad on Wed May 11, 2011 1:15 pm
Well, the dang sheared-off bolt is still stuck. The cold chisel idea didn't do much. I'm planning on removing the axle stub so I can get it on my drill press, or get another bolt welded onto the remains of the sheared-off bolt, or something. Man that axle nut's on tight! I will have to use a breaker bar. I ordered a new axle nut.
Post  Dawgz83948 on Wed May 11, 2011 1:48 pm
acorad wrote:Well, the dang sheared-off bolt is still stuck. The cold chisel idea didn't do much. I'm planning on removing the axle stub so I can get it on my drill press, or get another bolt welded onto the remains of the sheared-off bolt, or something. Man that axle nut's on tight! I will have to use a breaker bar. I ordered a new axle nut.
Your going to have to drill it out. What you should have done is cut the head off the bolt pulled the stub axle and removed it by tightening the stud until it fell out. Now the bent part is jammed in there and it'll never come out. I hope the threads on the stub axle are good.
Post  v8carreragts on Wed May 11, 2011 8:10 pm
Try buying a couple of left handed drills. Sometimes the broken bolt will heat up while drilling and the sharp left hand drill bites hard and it turns out the bolt.McMaster Carr has them.
Post  acorad on Thu May 12, 2011 8:29 am
v8carreragts wrote:Try buying a couple of left handed drills. Sometimes the broken bolt will heat up while drilling and the sharp left hand drill bites hard and it turns out the bolt.McMaster Carr has them.
Excellent idea!
Now, if I could only get my axle nut off...
Post  eclou on Thu May 12, 2011 9:52 am
I have a welder friend who has unfucked many a situation for me by welding onto a broken bolt/stud with enough slag to make a raised tab. He then uses vice-grips on the tab and backs the bolt right out. It takes him less than 10 minutes
eclou
eclou
Post  acorad on Thu May 12, 2011 11:24 am
Thanks eclou, I got the stub axle out this AM and will mess around with it a little on my drill press and my grinder. If that doesn't work I'll go to a welder.
I saw a good youube video the other day where a guy had a sheared-off bolt and he built up a little mound of slag with his wire welder and then welded a nut onto the slag, and then just ratcheted the bolt out.
I'm not sure a nut would work here as the CV joint bolts are really close to the rim of the stub axle, but probably welding another bolt onto the sheared-off bolt would get the bolt's hex up high enough to clear the rim.
PS: To remove the axle nut I had a breaker bar on it and a 10' piece of pipe. My 90lb son could hang on the end of the pipe w/o budging the nut - that's 900ft-lbs of torque! We got it off when he hung on the pipe and I pounded on the socket with a hammer.
Post  acorad on Fri May 13, 2011 11:18 am
eclou, I brought it to a welder and he did exactly what you described. Now all need is a couple hours free time and the car will be up and running again!
Post  Dawgz83948 on Fri May 13, 2011 1:49 pm
acorad wrote:eclou, I brought it to a welder and he did exactly what you described. Now all need is a couple hours free time and the car will be up and running again!
So...... how many dirty looks has your wife/gf given you during this process?
Post  acorad on Fri May 13, 2011 2:11 pm
She's actually been great, she loves the car.
Post  76-924 on Sat May 14, 2011 11:19 am
Porch wrote:If you've got the money, it would be a good time to purchase the Stage 8 locking CV bolts that have been for sale on rennlist for a while. They're about $80, but you'll never have to mess with 'em again!
I bought them for my car after I had the bolts back out as I was driving. Money well spent!
76-924
Post  acorad on Sat May 14, 2011 10:16 pm
76-924 wrote:I bought them [Stage 8 locking CV bolts] for my car after I had the bolts back out as I was driving. Money well spent!
I agree, I put them on my car yesterday. I'm back on the road!
Post  craighardy on Wed May 25, 2011 12:11 pm
Hey guys! Let me know as well, I would love to see my old car again. Also, just got my big turbo installed, running E85 at 18psi...I wonder how that frankenstein car of yours compares Wink
craighardy
Post  acorad on Wed May 25, 2011 5:48 pm
Hi Craig, good to see you here! Tell us about that Turbo of yours.
Post  craighardy on Thu May 26, 2011 11:04 am
I'm running a Vitesse Racing stage 3R kit [You must be registered and logged in to see this link.]
3" exhaust, 993T big red brakes, factory LSD etc. It should make 340ish rwhp, would love to compare it to my old LS1 car sometime.
As you can see, I like white with dark wheels! This one is also an 87.
craighardy
Post  944-LT1 on Thu May 26, 2011 11:30 am
craighardy wrote:I'm running a Vitesse Racing stage 3R kit [You must be registered and logged in to see this link.]
Beautiful! When you finna convert it?!?!
Post  acorad on Thu May 26, 2011 11:55 am
craighardy wrote:As you can see, I like white with dark wheels! This one is also an 87.
Ha! Yes, it looks very familiar!
Post  craighardy on Thu May 26, 2011 12:07 pm
As soon as acorad blows my doors off!
craighardy
