» Wanted to buy swap parts
New convert under way  - Page 29 EmptyToday at 8:48 am by nphd2000
» WTB 951 LSD Transaxle
New convert under way  - Page 29 EmptyYesterday at 9:27 am by Sirayden
New convert under way  - Page 29 EmptyThu Sep 16, 2021 11:03 am by Rich L.
» 944 Early Sun Visors vs Newer
New convert under way  - Page 29 EmptyWed Sep 15, 2021 4:11 pm by Hotrodz of Dallas
» Confused about brakes
New convert under way  - Page 29 EmptyMon Sep 13, 2021 10:52 am by Bmillar
» 944 ls track car
New convert under way  - Page 29 EmptySat Sep 11, 2021 7:11 pm by Leva
» LS Overheating Issue
New convert under way  - Page 29 EmptySat Sep 11, 2021 9:13 am by Hotrodz of Dallas
» 944 LS Conversion Parts near Charlotte, NC
New convert under way  - Page 29 EmptyThu Sep 09, 2021 12:44 pm by rrracing1970
» Sharkey's 944 corvette t56 swap thread
New convert under way  - Page 29 EmptyThu Sep 09, 2021 12:48 am by Raymond-P
» Full exhaust for rover V8 inc headers
New convert under way  - Page 29 EmptyTue Sep 07, 2021 8:19 am by Hotrodz of Dallas
September 2021
6789101112
13141516171819
20212223242526
27282930
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 29 of 31 Previous  1 ... 16 ... 28, 29, 30, 31  Next
New convert under way  - Page 29 Empty Re: New convert under way
Post  kevin924kevin Mon Nov 11, 2019 12:56 pm
Yes it is. The realization of many years of work has really got me excited to see my vision come to fruition.
Post  kevin924kevin Mon Nov 11, 2019 6:17 pm
Touch Down.
Post  Hotrodz of Dallas Tue Nov 12, 2019 8:17 am
You may need longer shock springs. Looks maxed out and you don't have all the weight on the rear yet.
Hotrodz of Dallas
Hotrodz of Dallas
Post  sparkydog Tue Nov 12, 2019 9:04 am
Looking great! Are your structural mods fully welded or tacked in at this point?
sparkydog
sparkydog
Post  kevin924kevin Tue Nov 12, 2019 3:33 pm
Hello first shocks have not been adjusted to drop the car. That's tonight's project. My bottom of rockers are sitting just about 9.5 in. Of the floor. Going to drop down to some were between 4 and 5 inches. Structural is tacked in place. Balance if my cage should be at the boarder. Waiting for my gas tank to hit the boarder then I will grab all at once. Valve covers should be there already. I have had trouble posting pics?? Anyways I will keep trying.
Post  kevin924kevin Tue Nov 12, 2019 3:38 pm
O[You must be registered and logged in to see this image.]
You can see the nose is a little high right now.
Post  kevin924kevin Tue Nov 12, 2019 3:40 pm
Post  Hotrodz of Dallas Tue Nov 12, 2019 4:09 pm
Ah ok. That makes sense. The first pic of the back of the car doesn't really show the ride height. Carry on. Very Happy
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Tue Nov 12, 2019 5:41 pm
So not familiar with inverted shocks. How much lower can this go?
Post  Hotrodz of Dallas Wed Nov 13, 2019 1:43 pm
Ideally, you want the shock adjusted so that it's in the center of it's travel while fully weighted. This gives the same amount of travel in both directions while driving over bumps and dips.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Wed Nov 13, 2019 2:19 pm
Ok. I have lowered the car but will waite for full weight to adjust properly.
Post  kevin924kevin Wed Nov 13, 2019 2:24 pm
Here is my intake set up.
Post  Hotrodz of Dallas Wed Nov 13, 2019 4:45 pm
That'll work good. Straight is the best intake. I would prefer a little more tube between the filter and MAF, but it'll be fine.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Wed Nov 13, 2019 5:15 pm
That may happen. Once we finalize the front bumper area height the filter could change. It will stay straight but the plan is a direct opening in the nose and fully shielded from the rad discharge. Work in progress should not change much.
Post  kevin924kevin Thu Nov 14, 2019 12:30 pm
Hydro boost / clutch plate ready.
Post  Hotrodz of Dallas Thu Nov 14, 2019 3:01 pm
That's much smaller than the mustang hydroboost, but the mustang has everything in one unit.
I'm sure you know this, but you can open the nipple on the brake fluid reservoir and run a hose from that to the clutch master cylinder.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Thu Nov 14, 2019 5:55 pm
I was going to ask that. Just to confirm.
Post  Hotrodz of Dallas Thu Nov 14, 2019 5:56 pm
kevin924kevin wrote:I was going to ask that. Just to confirm.
Confirmed Very Happy
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Thu Nov 14, 2019 5:59 pm
Thank you. Much appreciated.
Post  kevin924kevin Sun Nov 17, 2019 6:46 am
Coolant lines installed to rad.
Post  kevin924kevin Sun Nov 17, 2019 6:47 am
Post  kevin924kevin Sun Nov 17, 2019 8:49 am
So my plan now is I will bend aluminum tube to match the design I have layed out and just have the rubber hose at rad and water pump.
Post  Hotrodz of Dallas Mon Nov 18, 2019 8:11 am
I think you are going to have a very hard time bleeding the air out with the hoses like that. I feel you need the left one to be mounted where the tubing is up high. I always route the upper hose from the water pump to the left upper radiator nipple. And the hose from the thermostat goes to the lower right nipple.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin Mon Nov 18, 2019 8:50 am
Morning I have routed my lines wrong? I will put a burp point in the heater lines to bleed.
Post  Hotrodz of Dallas Mon Nov 18, 2019 9:39 am
Yes, they are routed wrong. The top nipple on the water pump goes to the top left nipple on your radiator. It should be built in a way that is stays high in the engine compartment. The nipple on the thermostat needs to go to the bottom right radiator nipple. This is the correct flow for an LS. You need to install a coolant reservoir like originally came on the 924-944. This will need to be your highest point in the cooling system. I can't tell from your pic if the radiator has a 5/8" nipple for the coolant reservoir to attach to. It will need this to fill the cooling system. There should be a small 5/16" coolant pipe under the front of the intake. This needs to go to the reservoir as well, so that the air will bleed from the heads.
This pic shows what needs to be done.
Hotrodz of Dallas
Hotrodz of Dallas
